Mounting Bar LEDs?
Page 1 of 1 [7 Posts]
PostPosted: Sun Feb 10, 2013 8:25 pm    Post subject: Mounting Bar LEDs? Reply with quote  Mark this post and the followings unread
I have a VCPS-8 PCB that's fairly close to the top of my backlog at the moment.
I also have a few of these DIP bar LEDs, which look a lot like one of the versions of the VCPS-8 from the build docs.
But I haven't the foggiest idea how to mount them to a panel. Suggestions?
 Filesize:  90.63 KB
 Viewed:  14 Time(s)
PostPosted: Mon Feb 11, 2013 12:17 am    Post subject: Reply with quote  Mark this post and the followings unread
on my 1st build i just glued it to the panel.
another solution would be a sub-PCB?
fonitronik at
Audio files: 51
PostPosted: Mon Feb 11, 2013 2:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Solder them onto a piece of stripboard, then add 4(or more) mounting posts on the front side which are just the right depth for the display to protude through the main panel. Use some nice countersunk 3mm bolts with a hex head from the front so it looks specky. Cool
We would lose our friends.
So,.........
analog_backlash
PostPosted: Mon Feb 11, 2013 3:30 am    Post subject: Reply with quote  Mark this post and the followings unread
I've had the same thoughts about mounting DIL switches on front panels (which I've used in my "Super Stylophone" but I still haven't put it into a proper case yet). I had the added problem that I wanted them in sockets, so that they could be replaced easily (not having a great guaranteed number of actuations - around 2000). I have the sockets on stripboard and I've cut the rectangular holes to just fit the sockets, flush to the front panel and then plugged in the switches into these. Currently they are not firmly attached, but I planned to use spacers either bolted of glued to the front panel to fix the stripboard in place. Not very satisfactory, I know.
Really, I should use toggle switches, but they are much, much more expensive than the DIL switches...
Gary
bubzy
Audio files: 47
PostPosted: Mon Feb 11, 2013 5:36 am    Post subject: Reply with quote  Mark this post and the followings unread
+1 for glue Very Happy
araldite or something similar, so you get a nice solid hold.
the other method is nice too as unkle k said, but that requires some neat drilling.
me monkey, me glue Very Happy
_Richard_ Smile
LektroiD
PostPosted: Wed Mar 06, 2013 7:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Hot glue gun if you have one.
My tunes available here
(check out the new Electro-Funk LP)
PostPosted: Thu Mar 07, 2013 1:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
or JB Weld Very Happy
fonitronik at
