<on air> Various Artists June Solstice live streaming concert
 Forum index » Clavia Nord Modular » G2 Patches - Completed » FX
3phase chorus
Page 1 of 1 [2 Posts]
ian-s
Audio files: 42
G2 patch files: 625
PostPosted: Fri Mar 18, 2005 1:44 pm    Post subject: 3phase chorus Reply with quote  Mark this post and the followings unread
Another chorus, this one is from the Polysix/Solina style. Three BBD’s centered around 12ms. Modulation comes from two, triphase sines. One at ~0.6Hz the other 6Hz. Each delay is modulated by the sum of the slow and fast sines at 0, 120 and 240 deg respectively.
Not part of the original but another tip from the SynthDIY archives, the LFO shape is a modified sine, a little flatter on the bottom, sharper at the top. This makes the frequency change slower at the bottom of the cycle (good for phasers and flangers, use a diode module to get the upside down McDonalds wave)
I also tried a 4 phase version using IK’s quadrature sine (as an LFO) and a couple of inverters, seems the Clavia chorus is a 4 phase design (with a single LFO) because it sounds very similar.
poly6.pch2
three phase chorus
 Filename:  poly6.pch2
 Filesize:  2.75 KB
 Downloaded:  1688 Time(s)
doctorno
G2 patch files: 8
PostPosted: Thu Jan 29, 2009 11:41 am    Post subject: Used your chorus for my Juno Emulation Reply with quote  Mark this post and the followings unread
Hello ian-s,
I hope you do not mind, that I have used your chorus patch to improve an emulation of the Roland Juno 6 that I made. I love your patch, it sounds great.
MH Juno Var.pch2
 Filename:  MH Juno Var.pch2
 Filesize:  6.35 KB
 Downloaded:  1186 Time(s)
