LM324 / LM741 TRI SQUARE VCO | LM741 VC LFP
Page 1 of 1 [11 Posts]
2kohm
PostPosted: Thu Feb 21, 2013 1:09 am    Post subject:  LM324 / LM741 TRI SQUARE VCO | LM741 VC LFP
Subject description: diy synth on breadboard with schematic
Hello Diyers,
i played around with the LM324 and LM741 opamp!
Schematics (selfdraw) but with the LM741 (works also with other opamps)
LM324 is testet! works like charm.
i have one problem. i add another lm324 in the same config to use as an LFO i get sound from the freq of the lfo and a klicking noise in high freqs in the audio??? is this an error of my PSU? i thnink i have to use a Virtual GND ?
regards.
2kohm
Layout with 2 LM741
 Filesize:  520.23 KB
 Viewed:  300 Time(s)
Pinout
 Filesize:  804.37 KB
 Viewed:  131 Time(s)
Shop
Videos
Stromakustik.de
PostPosted: Thu Feb 21, 2013 5:42 am    Post subject: Reply with quote  Mark this post and the followings unread
It sounds great.
Do you use bypass caps? That might solve the clicking. You should have a 0.1uF cap that goes from the + to the - power pins on each ic. keep the caps as close to the ic as possible.
JacobWatters.com
2kohm
PostPosted: Thu Feb 21, 2013 7:07 am    Post subject: Reply with quote  Mark this post and the followings unread
THX Very Happy il try it today
Shop
Videos
Stromakustik.de
2kohm
PostPosted: Fri Feb 22, 2013 6:28 am    Post subject: Reply with quote  Mark this post and the followings unread
perfect Very Happy
last night i found a easy way to make an APC out of my circuit!
the "APC" steps can provided also by de resonance Pot from the filter!
lets build the LM324 APC Very Happy
any ideas ?
Shop
Videos
Stromakustik.de
2kohm
PostPosted: Wed Mar 20, 2013 8:38 am    Post subject: schematic with lm324 Reply with quote  Mark this post and the followings unread
schematic
LM324 tri/sqr OSC
 Filesize:  88.19 KB
 Viewed:  298 Time(s)
Shop
Videos
Stromakustik.de
Scott Stites
Audio files: 96
PostPosted: Wed Mar 20, 2013 2:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's nice work. I also dig your breadboard layout. What are those green switches you're using for keys? I don't think I've seen anything like those before.
My Site
2kohm
PostPosted: Wed Mar 20, 2013 11:12 pm    Post subject:
Subject description: HIGHLY KS01-B-G
Thanks Very Happy
The Switch
http://www.tme.eu/de/details/ks01-b-g/knopfschalter/highly/#
Shop
Videos
Stromakustik.de
Scott Stites
Audio files: 96
PostPosted: Thu Mar 21, 2013 10:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool! Thank you.
My Site
baudrate
PostPosted: Fri Mar 22, 2013 7:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Do you have the schematic for the LPF?
2kohm
PostPosted: Sun Mar 24, 2013 11:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes!
SIMPLE VCF
remove the Diode ( hard clipping and distortion with higher reso)
i used 470K input resitors on pin 3 ( pin 2 works also as input )
Shop
Videos
Stromakustik.de
baudrate
PostPosted: Mon Mar 25, 2013 9:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Sweet! Thank you.
