USB-MIDI2CV anyone?
Page 1 of 1 [7 Posts]
Boerge
PostPosted: Wed Mar 06, 2013 12:26 am    Post subject: USB-MIDI2CV anyone? Reply with quote  Mark this post and the followings unread
I want to use a cheap MIDI-keyboard for a DIY-Synth. The Keyboard has USB, so I have to transform it to CV-signals. Are there any ready-to-use solutions like the MIDI2CV-moduls out there?
regards
Boerge
...ich will doch nur löten...
danielwarner
PostPosted: Wed Mar 06, 2013 2:28 am    Post subject: MIDI-to-USB Reply with quote  Mark this post and the followings unread
I've never seen a USB-to-CV converter, you'll probably have to use a MIDI-to-USB cable with a MIDI-to-CV module
danielwarner
PostPosted: Wed Mar 06, 2013 2:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Nevermind, Doepfer has one:
http://www.doepfer.de/a1903.htm
Boerge
PostPosted: Wed Mar 06, 2013 3:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, I found that too. But I rather thought about a little PCB, USB in, CV/Gate out. USB=>MIDI=>CV/gate seems a long way Wink (delay?) The only DIY-thing I found was here:
http://www.sdiy.org/knas/modsynth/usb2cv.php
But the MC1408 seems not to be available Sad
regards
Boerge
danielwarner
PostPosted: Wed Mar 06, 2013 3:21 am    Post subject: Reply with quote  Mark this post and the followings unread
The MC1408 can be found on eBay:
http://www.ebay.com/sch/i.html?_trksid=p2050601.m570.l1313&_nkw=MC1408&_sacat=0&_from=R40
Good luck with that circuit!
analog_backlash
PostPosted: Wed Mar 06, 2013 3:59 am    Post subject: Reply with quote  Mark this post and the followings unread
I also know a UK source for this chip:
http://www2.cricklewoodelectronics.com/Cricklewood/product.php?productid=11996&cat=0&page=1
It's more expensive than eBay, but I've bought ICs from them before and I've had no problems. I'm always a bit suspicious of eBay, unless I've had a specific recommendation (although they may well be perfectly OK).
Gary
richardc64
Audio files: 25
PostPosted: Wed Mar 06, 2013 7:39 am    Post subject: Reply with quote  Mark this post and the followings unread
There's nothing special about the MC1408, except maybe its scarcity. Equivalents with the same pin out are DAC08, 0800, 0802, all of which are still available.
analog_backlash wrote:
I'm always a bit suspicious of eBay...
Werd.
"It's quite OK to make music with tea spoons and rubber bands!" -- Blue Hell
