Max Voltages and the 259 Clone...
Page 1 of 1 [2 Posts]
phdinfunk
PostPosted: Sat Mar 09, 2013 4:19 am    Post subject: Max Voltages and the 259 Clone...
Subject description: A few foibles, some audio, and a question
With my own 259 clone I have tried to do away with the distinction between CV and Audio, hoping eventually to integrate it cleanly into my Frac-Rac stuff that lives back in the USA. To that end, I put everything on 1/8" jacks.
However, as I was patching around on it, I took the DC output, which is pretty high voltage, from the mod osc and plugged it into the principle osc sync input and burned the diode.
This makes me wonder if:
1) The voltage coming out of that osc is too hot for other stuff, and I should reduce it or....
2) The variable Sync input on the Principle osc is fragile and I should always be careful with it.
If number 1 is true, then do people have trouble with inputs getting damaged from Buchlidian Function Generators?
The variable sync does sound very nice though. Here I sweep it from 0 to 10 then back to 0.
https://soundcloud.com/phdinfunk/syncing-princ-osc
Here are also a few more sounds from my SMT cloned 259 in its current iteration:
Sym+Order+Timbre:
https://soundcloud.com/phdinfunk/symmetry-order-timbre
Timbre + Order + T.M. + A.M.:
https://soundcloud.com/phdinfunk/nice-like-underworld
andrewF
PostPosted: Wed Mar 13, 2013 2:01 am    Post subject: Reply with quote  Mark this post and the followings unread
this doesn't help, but i keep thinking the title of this thread would be a great name for a band
