New member on board.
Page 1 of 1 [8 Posts]
baydar
PostPosted: Mon Mar 11, 2013 9:54 pm    Post subject: New member on board. Reply with quote  Mark this post and the followings unread
Hello Gens,
I would like to say hello, i am a new member.
I am just fascinated by all DIY thing.
So far i have build simple noise maker 74hc14, and 4017 sequencer,
but i have decided to build my own Lunetta.
I am also trying to write a blog about it, or at least some of the main events.
http://marekmuzyka.wordpress.com/diy-2/
So that iz all, so to speak i was greatly influence by: textual and his works, that i have find in this forum.
Take care
bubzy
Audio files: 63
PostPosted: Tue Mar 12, 2013 1:26 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome to electro-music !
make sure that you post sounds and pics here too Smile
_Richard_ Smile
PostPosted: Tue Mar 12, 2013 1:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Welcome aboard (fellow Montrealer)! There are plenty of great ideas and tips to be found in this forum... maybe too many Smile.
James.
roglok
PostPosted: Tue Mar 12, 2013 7:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
hi there and welcome !
e-m is an awfully nice place and has been an indispensable resource for bulding my own synth.
hope you'll feel the same!
thumb up
analog_backlash
Audio files: 21
PostPosted: Wed Mar 13, 2013 6:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Willkommen! Bienvenue! Welcome!
Just had a look at your web site and you seem to have a good modular system there (better than mine - I can't afford Doepfer, Wiard etc at the moment, so I'm building everything from scratch). I'm in a similar position with my lunetta build. It's a bit minimalist at the moment, as I'm testing things out on prototyping board. I will post something soon about the progress I've made.
Ditto that!
Gary
baydar
PostPosted: Wed Mar 13, 2013 7:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you guys, i will post some photos,
And i will definitely ask you some lots of questions.
autowitch
PostPosted: Sat Mar 16, 2013 7:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Howdy!
That is a nice looking synth. I am also a beginner here. Hopefully our questions help each other.
baydar
PostPosted: Tue Mar 19, 2013 11:31 am    Post subject: Next Reply with quote  Mark this post and the followings unread
I have able to, to drill the rest of the holes, and I have found out that I like drilling...Smile I was planning to use 1/8 inch jacks, but than I have decided to go instead of with banana connectors.
I like the banana connectors ,because these are color coded, and there is less soldering, and they look more cool, as suggested by
So , Green will be IN, and Red will be Out, I will see what will be the Reset, probably Yellow. or Purple.
I have installed the Pots, the switches and the connectors. Next is to glue in the diodes and the wiring.[img]
So there, my Second post.
