reklrekl
Posted: Thu Mar 28, 2013 10:54 am Post subject:
YuSynth VCO Problem |
Hi guys, i am looking for a solution for a Problem with my VCO:
The OSC runs at a fixed frequency (no matter if I turn the Pots or apply CV) and the Waveform sounds like some spikes running at 0.5 Hz. I cant show u the Waveform, dont got an oscilloscope yet....
At the pin1 of the OPA2137 i get a voltage of around -2.5 to 2.5 V when i turn the pots....
Thanks for any help!
Edit: triple-checked every connection now...
Edit 2: Here I have a view of the Output of U6 (TL074) at pin 1
and an image of pin 3 of the J111 (J112 in my case)
please tell me how these Images should look, i can imagine U6 shall look like that... |
littlem4tt
Posted: Sat Nov 09, 2013 1:47 pm Post subject:
I had similar readings. Turned out it was fake lm394's. |
yusynth
Posted: Sun Nov 10, 2013 9:59 am Post subject:
An easy way to check if the LM394 is fake is simply to take it off the socket and plug in the socket two BC547. If the VCO works fine with the BC547 then it should with the LM394. _________________ Yves |
yusynth
Posted: Sun Nov 17, 2013 3:44 am Post subject:
littlem4tt wrote: | I had similar readings. Turned out it was fake lm394's. |
Where did you get those fake from ? To prevent others to buy them... _________________ Yves |
littlem4tt
Posted: Sun Nov 17, 2013 12:45 pm Post subject:
Actually the guy from ebay replaced the ic's!! I had already given positive feedback before i tested them but he still replaced them afterwards so i dont think i will name and shame. The package looked exactly the same as the previous ones so it was not his fault.
I made the cv standard module to help in calibrating the vco. I highly recommend this as an early build as i have now gone back and re-calibrated all my other oscillators against this wonderful module. Thanks Yves! |
