Rene Schmitz 555 adsr debug/problem
Page 1 of 1 [3 Posts]
sonrie69
PostPosted: Sat Apr 06, 2013 9:05 am    Post subject: Rene Schmitz 555 adsr debug/problem
Subject description: adsr contruction and simulation differences
hi people.... i built rene's 555 adsr .. i am having problems.. i use proteus for simulating the schematic.. in proteus everything is find.
but when i built i find some problems.
the output of the tl081 is up when gate is down.. but when gate is up, the adsr work well...
i measure the volt in the tl081 and i find that is 0.3v against the 0.6 v in proteus... is possible that this difference is the issue why the output is up without gate in???
i attach the schems and the pcb
 Filesize:  338.54 KB
 Viewed:  97 Time(s)
 Filesize:  1.34 MB
 Viewed:  188 Time(s)
 Filesize:  9.04 KB
 Viewed:  130 Time(s)
JovianPyx
Audio files: 184
PostPosted: Sat Apr 06, 2013 12:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
The output of the TL081 should be identical to the voltage at it's non inverting (+) input. This should be measured using a good DVM or DMM or oscope (high impedance). If not, check for solder problems around the TL081 and it's connections.
Time flies like a banana.
corruptio optimi pessima
sonrie69
PostPosted: Sat Apr 06, 2013 1:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
hi JovianPyx, thanks for the answer.. i checked the connections ...actually, when the gate in on, the tl081 works fine, and the output equals the + input...
it's like the voltage on + input is out of range so the tl081 output is V+. i am doubting about the my pcb design..
another thing i find is : on R5 the voltage is 0.04 volts, but in proteus is .12 volt. i tried to enhance the power there by reducing R5 but (in my little experience) i doesn't help.. i like the Q2 takes more power on the pcb than the simulation..
