Discrete Transistor 2040 SVVCF
Page 1 of 3 [59 Posts]
Goto page: 1, 2, 3 Next
Scott Stites
Audio files: 96
PostPosted: Mon Apr 08, 2013 8:52 pm    Post subject: Discrete Transistor 2040 SVVCF Reply with quote  Mark this post and the followings unread
I guess it's been a while since I posted anything of any interest. Hopefully this may be to someone. Like any synth DIYer, I have a number of circuits that have fallen to the wayside - some for good reason, others because I started chasing after a brand new shiny.
A long time ago, when TH was developing the Mankato filter, I became interested in the 2040. Romeo Fahl told me that one design of the original 2040 filter that really kicked butt was the state variable configuration of the chip. I recall him saying that it was so thick, you could drink it with a straw or something like that. For a few years the idea kicked around in my head to try JH's 2040 gain cell in that configuration - if I could figure it out. I think I did figure it out. Well - I figured out something anyway that LP, BP and HP outputs. And, yes, it was much thicker than any OTA variant of the SVVCF I'd tried out. Much thicker. It really was a monster.
I remember sending the schematic to both JH and Rene Schmitz, because I'd cobbed elements from both of them. I don't think I ever heard back from Rene, but JH's comment was mainly "How come you are buffering the resonance". I loved that guy. Anyway, I had no good answer other than the fact that I had that op amp stage free, so....
Anyway, I did two variants of it: one used 2N3904s and 2N3906s, and the other I used THAT parts on. TBH, I don't think there was enough difference between the two to justify the cost of the THAT transistors, but they do make it somewhat easier to build. You'll notice on that schematic I took JH's advice, though it doesn't make any difference other than not look quite so ludicrous. You could use that stage, I suppose, to produce a notch output.
So, I submit to anyone interested the two versions of the 2040 Transistor State Variable Filter. I imagine, if you're successful, you will find that it is a far more...aggressive...filter than your OTA SVVCF. By far.
I've attached two samples I made of the filter - both were the discrete version (2N3904 and 2N3906). This same version was the filter I used in this video - you'll see a shot of it on the breadboard as the video starts.
http://www.youtube.com/watch?v=KzqaNMK9B80
Take this, brother, may it serve you well.
EDIT: Replaced schematics with versions that fixed erroneous bypass cap values.
THAT Transistor Version (fixed bypass cap values)
 Filesize:  629.99 KB
 Viewed:  1163 Time(s)
Discrete Version (bypass cap values corrected)
 Filesize:  646.52 KB
 Viewed:  1145 Time(s)
2040vcf_lpbphp_seq.mp3
Samples of LP BP and HP outputs of discrete version
 Filename:  2040vcf_lpbphp_seq.mp3
 Filesize:  10.05 MB
 Downloaded:  740 Time(s)
2040svvcf_comp.mp3
Composite of samples taken with discrete version
 Filename:  2040svvcf_comp.mp3
 Filesize:  11.8 MB
 Downloaded:  652 Time(s)
My Site
delayed
PostPosted: Tue Apr 09, 2013 12:00 am    Post subject: Reply with quote  Mark this post and the followings unread
neat stuff. i love the 2040 filter in the Cat.
diablojoy
PostPosted: Tue Apr 09, 2013 1:35 am    Post subject: Reply with quote  Mark this post and the followings unread
very nice scott and it sounds great.
if its ok and i get some time soon i may draw up a board for the 2n3904/3906 version
ask where the hell am I
as good an answer as any
LFLab
PostPosted: Tue Apr 09, 2013 2:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice work Scott!
Still meaning to do a layout using BC847bs and BC857bs double transistors (SMT) since these are cheap and easy to get (and you can get a matched version as well). Good to hear that the filter sounds nice (at work now, so didn't listen to the samples yet).
I can feel this bubbling to the top of the backlog already Very Happy
delayed
PostPosted: Tue Apr 09, 2013 2:50 am    Post subject: Reply with quote  Mark this post and the followings unread
How can you tell how well they are matched? I looked up the datasheet and did not see that information.
Scott Stites
Audio files: 96
PostPosted: Tue Apr 09, 2013 5:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Delayed,
Do you mean the THAT parts? They're matched to 500 uV, if they're of the same gender (PNP or NPN). The discrete parts can be hand-matched. Actually, you can get pretty good initial results even if you don't match them.
I did make one small change to the discrete version that shows up in the 2040 version - the 150 pF cap across R7. IIRC, that fixed a problem with the resonance getting some interference at high levels. It's on this attached version I drew up a couple of days after the one above.
Cheerio,
Scott
Edit: Posted in first post of this thread
My Site
LFLab
PostPosted: Tue Apr 09, 2013 7:14 am    Post subject: Reply with quote  Mark this post and the followings unread
If delayed is referring to the BC847bs parts I mentioned, no reference to the degree of matching is mentioned in the datasheet. I believe "L-1" on the muffwiggler forum checked a few and came to good results. I have used them but not checked them for matching.
However, the BCM847bs is a matched dual and that does have the mismatch mentioned in the datasheet, the dual PNP part is BCM857bs.
For even more weirdedness, there's a NPN-PNP dual available as well, the BC847pn.
Who says there aren't any new fun parts coming out for Synth-DIY? Fascinating stuff!
Did I mention they are cheap as chips? Well, they are!
30 eurocents each for a matched PNP if you buy 25 of them at Mouser.
Paradigm X
PostPosted: Tue Apr 09, 2013 7:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow
Neat looking circuits. Cant listen here at work sadly.
I was actually thinking of making a version of JHs discrete 2040 circuit, but its a bit (well ok, lots) over my head.
Im trying to work out how best to build using THAT chips, of which i have a few; In terms of the matching, which ones are critical? I guess Q1-Q8 are, can the rest be 2n390x ? But could be wildly wrong.
Many thanks,
Ben
PostPosted: Tue Apr 09, 2013 11:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Any reason to not implement with 2 x TL074 and 1 x TL071 instead of the TL072's?
Scott Stites
Audio files: 96
PostPosted: Tue Apr 09, 2013 1:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
@Diablojoy It'll be interesting to see what you come up with for a board.
@LF Lab: Rene's 2040 design was actually for surface mount - this could turn into a very tiny filter, I imagine, if you went all surface mount.
@Paradigm: Yeah - you could use 2N3904's with the THAT part. You might want to compare yourself, but generally if you get your parts from the same lot, the matching these days would likely be quite good enough for this filter already. I seem to recall Rene telling me that he didn't bother too much with matching on his filter.
@Elmegil: Any color you choose Smile. Generally when I do stuff like this, I start off with dual op amps because I may choose later on to put better quality audio op amps in, and the better quality DIP op amps I prefer are usually dual op amps; rarely are they in quad (I'm rather enamored with the OPA2134). Another reason is I like to keep the control portion separate from the audio portion. But, that's just me, and it probably wouldn't make a lick of difference how you select and arrange them.
My Site
diablojoy
PostPosted: Tue Apr 09, 2013 2:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah they are really good however LF442 is a reasonable replacement and quite a lot cheaper so i use them generally.
Thanks i am leaning toward less wiring - euro format acceptable but able to be used in other formats as well, seems to be the direction the majority
are heading , though i still build in a custom size myself.
The circuit itself looks very small though there is quite a lot panel
controls and jacks that could suck up the space.
will aim for a board size of 100 x 48 mm, narrower if i can get it components and silk screen on both sides of course.
Dan Lavin
Audio files: 21
PostPosted: Tue Apr 09, 2013 6:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice one, Scott! Been playing with transistors myself a lot lately. Very Happy
Synth DIY since 1977!
Scott Stites
Audio files: 96
PostPosted: Tue Apr 09, 2013 9:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey Dan,
I've been playing with BBDs lately. Lotsa fun, those too.
Cheerio,
Scott
My Site
comrade_zero
PostPosted: Wed Apr 10, 2013 12:23 am    Post subject: Reply with quote  Mark this post and the followings unread
First off, Mr. Stites, a hearty "thank you" for taking the time and energy to share this with us. This filter sounds good (I am a sucker for filters.) Secondly, any idea if or how it would behave on -12/+12v?
Especially if someone is looking to a Euro-format board? Thanks again.
c_z
LFLab
PostPosted: Wed Apr 10, 2013 1:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Scott Stites wrote:
....(I'm rather enamored with the OPA2134).....
Me too! I like them for "hi-fi" purposes, do you feel that the difference is noticable for synth applications like a VCF as well? Must give it a try.
I've used OPA4134 in a headphone amp, but you can get those in SMT only, no DIP.
StephenGiles
PostPosted: Wed Apr 10, 2013 1:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Scott Stites wrote:
Hey Dan,
Cheerio,
Scott
Through zero flanging perhaps? Are you aware that Mike Irwin (where is he now?) designed a TZF using just one BBD?
Paradigm X
PostPosted: Wed Apr 10, 2013 2:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks very much for replying. I was thinking about this last night after I had posted; im only going to use it as a filter, not an oscillator, and probably without CV for the first attempt, so the transistor matching isnt critical at all. May as well save the THATs for more critical circuits (as you said in the first post, doh ! Wink Laughing )
Ben
Scott Stites
Audio files: 96
PostPosted: Wed Apr 10, 2013 7:06 am    Post subject: Reply with quote  Mark this post and the followings unread
That's probably a good idea not to use it as an oscillator - IIRC, it doesn't self-oscillate, but, heck, it's been five years.
I noticed I still have my THAT version on breadboard. It's a bit squashed, but I'll have to see if it works this weekend.
My Site
Paradigm X
PostPosted: Wed Apr 10, 2013 7:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Embarassed
Well, thats saved me a lot of time. Doh
im new to all this, if it isnt obvious (!) so i just assumed all (most?) filters do v/oct resonance.
Ill have to try to get it up and running and take it from there.
thanks
J3RK
PostPosted: Wed Apr 10, 2013 10:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Very nice! This just shot up to the top of my "need to build" list. I had planned to build those gain cells in SMT on a little chicklet type board with DIP pins to use in multiple designs. It may be time to do that now. Cool design, and it sounds incredibly good. Thanks for posting this Scott!
If I make the gain-cell-plug-in boards, maybe I should add an LM4040 for the +5V so it's built in. Then it would only need two power pins from the main board.
Scott Stites
Audio files: 96
PostPosted: Wed Apr 10, 2013 11:19 am    Post subject: Reply with quote  Mark this post and the followings unread
An LM4040 would be pretty spiffy - the gain cell boards would be actually quite useful - you could use them in Rene's 2040 circuit as well.
Paradigm, actually I should have mentioned the self-oscillation. I'm fairly sure it didn't self-oscillate back when I was playing with it, but I should check that again. Dang, I've played with so many filters through the years, they're starting to run together in my brain Very Happy.
And you're right - most filters will self-oscillate. Seems to me I've played with a couple of SVVCFs that didn't, but one I do know that oscillates like a bat out of hell is Ray Wilson's SVVCF.
My Site
Paradigm X
PostPosted: Thu Apr 11, 2013 4:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Scott.
Appreciate your time.
Another basic query, all the bypass caps are shown as 0.1nF, i thought 0.1uF was more common? Any reason for this?
Cheers!
Ben
Scott Stites
Audio files: 96
PostPosted: Thu Apr 11, 2013 6:45 am    Post subject: Reply with quote  Mark this post and the followings unread
The reason would be my brain. 0.1 uF would be the correct value. I'll fix that when I can - I'm writing this from work. Our crude rural internet service is down because of an ice storm.
My Site
Scott Stites
Audio files: 96
PostPosted: Thu Apr 11, 2013 2:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Fixed'em.
My Site
Paradigm X
PostPosted: Fri Apr 12, 2013 1:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Great stuff. Glad to know im not going mad!
Thanks again for posting this, its a lovely squelchy filter.
Smile
