  Various Artists Live streaming concert in memory of Antimon
Noise gen / Sample & Hold cap substitute
Page 1 of 1 [5 Posts]
feggster
PostPosted: Fri Apr 12, 2013 5:33 am    Post subject: Noise gen / Sample & Hold cap substitute Reply with quote  Mark this post and the followings unread
hi, I'm building this module and have no 680nf cap! can I sub it for 1uf ?
hv0190
PostPosted: Tue Apr 16, 2013 8:56 am    Post subject: Reply with quote  Mark this post and the followings unread
If you use a 1uF instead of a 680nF cap what you actually do is change the time constant (TC = r*c), in other words: it simply takes longer to charge and discharge the cap, or again in other words: this will make the slewing time longer (experts correct me if I'm wrong).
Just give it a try, it shouldn't spoil the functionality of the rest of the module.
philoop
PostPosted: Tue Apr 16, 2013 10:29 am    Post subject: Noise gen / Sample & Hold cap substitute Reply with quote  Mark this post and the followings unread
I use for my sample and hold 1nf polystyrol
Deploying dual-wavelength fNIRS, we interrogate 16 locations in the forehead when eight able-bodied adults perform deception and truth-telling scenarios separately.
PostPosted: Tue Apr 16, 2013 10:30 am    Post subject: Reply with quote  Mark this post and the followings unread
I usually try and see if I have two caps I can put in parallel that will add up to the value (or near the value) I need.
470 + 220 is close, 560 + 120 would be dead on.....
feggster
PostPosted: Tue Apr 16, 2013 3:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks for replying, I ended up ordering some 680nf caps, before that It was a toss up between 1uf or 470nf and 2x 100nf Smile
