Doepfer Modules up for Auctions.
satamile
PostPosted: Thu Apr 18, 2013 9:40 pm    Post subject: Doepfer Modules up for Auctions.
Subject description: A-140 ADSR, A-127 , CB-88 Cowbell Module, Doepfer A-128 Fixed filter Bank
Hi, I've got a lot of Doepfer Modules up on Ebay for auction most without a reserve. Jump in there and get somthing special for your Modular rack. I have a Doepfer Filter CV controlled A127 , pretty awesome and lots of other little goodies. Switching my studio around some so I can travel and produce.
Enjoy!!
http://www.ebay.com/sch/electrobotsz/m.html?item=321110089287&ssPageName=STRK%3AMESELX%3AIT&rt=nc&_trksid=p2047675.l2562
Analogue Systems VCLFO
IN USE
The RS80 is a flexible LFO with an extremely low minimum frequency (one cycle every 50 seconds) that allows you to create a variety of slowly varying modulations and effects. Its maximum frequency lies in the middle of the
 Filesize:  33.13 KB
 Viewed:  905 Time(s)
Module A-127 is a triple resonance filter unit. It contains three separate voltage controlled band pass filters. Each filter has it's own LFO (triangle waveform) with LED display and adjustable frequency and amplitude. Instead of the internal LFO an exter
 Filesize:  723.91 KB
 Viewed:  65 Time(s)
Module A-128 (Fixed Filter Bank) is a filter bank, made up of 15 parallel band pass filters, all with fixed middle frequencies and bandwidth:
Controls 50 Hz ... 11 kHz
Each band pass filter has its own amplitude control knob, with which that frequency ba
 Filesize:  853.48 KB
 Viewed:  67 Time(s)
