How to keep your prints for a long long time
Page 1 of 1 [8 Posts]
isak
PostPosted: Sat Apr 20, 2013 12:50 am    Post subject:  How to keep your prints for a long long time Reply with quote  Mark this post and the followings unread
Hi guys.
Well, I have this great idea of how to keep the ink printed circuits from the printer for a long long time if not for a life time.
The idea started when I cut one of the clear paper and the ink just remove by me by mistake, so I thought why the hell not to laminate the clear paper?
I was afraid that the laminate machine will burn the whole deal, so I made a test.
It's perfect!
Didn't burn at all and the ink is whole, no gaps, nothing.
Today I'll laminate all the circuits I have and keep them without warrying that nothing will happend to them.
PS I try it only with laser print, not with regular ink printer.
If someone can check this with ink printer that would be great.
Isak E.
Audio files: 562
PostPosted: Sat Apr 20, 2013 9:07 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm not entirely sure if that is such a good idea, maybe it works (and then it's a great way to protect them) but you now introduce an extra layer
between the print and the PCB where light can get through.
SoundCloud BandCamp AcidTrasH Stickney Synthyards
isak
PostPosted: Sat Apr 20, 2013 9:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi PHobos.
I already eatched it, works like a charm.
I use a pic frame with glass, the light is in the center excactly above the print so there is no problems Smile
Audio files: 562
PostPosted: Sat Apr 20, 2013 10:31 am    Post subject: Reply with quote  Mark this post and the followings unread
in that case thumleft
Broadwave
Audio files: 6
PostPosted: Sat Apr 20, 2013 11:30 pm    Post subject: Re: How to keep your prints for a long long time Reply with quote  Mark this post and the followings unread
I always use a laser printer on clear acetate... But I find the toner isn't put down thick enough, so I have to print it twice and "double up" to get the tracks dark enough for exposure Rolling Eyes
I'm going to try a few experiments with ink jet based tracing paper to see if that helps... or get a better laser printer Wink
isak
PostPosted: Sun Apr 21, 2013 12:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Andy.
i use HP LaserJet CP2025.
very deep colors, no need to print twice, cheap and great laser printer.
what i did with the lamination is cause after a while the ink is coming down, this is why.
anyway check the printer, its a good one. Very Happy
steffensen
PostPosted: Tue Apr 23, 2013 2:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Good idea Isak. Smile
isak
PostPosted: Tue Apr 23, 2013 3:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Smile
