FA: OBERHEIM SEM VINTAGE MODULE with RARE MOOG PANEL
telefunken
PostPosted: Sat May 04, 2013 4:00 am    Post subject: FA: OBERHEIM SEM VINTAGE MODULE with RARE MOOG PANEL Reply with quote  Mark this post and the followings unread
Here for sale one of the most rare version of vintage Oberheim SEM module.
According to information, only 5 of them made in time.
No question, this set is the biggest sounding single vintage Oberheim SEM module ever, because beside of original 2 oscillators of the Vintage SEM module, you have on top 4 more SUB OSCILLATORS !
With this special construction, this Oberheim SEM module, sound wise works like 4 Voice version .
With additional Sub Oscillators, you are able to make the biggest bass and lead sounds ever.
No any single new or vintage SEM module on the market or on ebay can sound like this one due to in built sub oscillators.
Expander module has all of the cv controls of SEM module. With 35 connections on the expander panel, SEM works like a modular system .
Patching everything into everything freely , will make your work more fascinating that a normal SEM module, with this way the sound creation is limitless.
All the oscillators are perfectly tuned. All the knobs and switches works perfectly.
It has 35 high quality patch input and output jacks, 4 switches for muting the oscillators, 4 very nice coloured big blue LEDS and 12 "original Cosmo MOOG knobs .
The custom Moog panel is ENGRAVED (not silkscreened), with each functions name in silver
The unit has 110V power supply in-built , i will be sending with a high quality 220V to 110V step down converter, which works perfectly with the unit.
Good luck to own one of the most rarest version of vintage Oberheim SEM module
Moog Panel Features :
3 CV Input for OSC 1 (CV in for SAW1, CV in for SQUARE 1, CV In for BOTH)
3 CV Input for OSC 2 (CV in for SAW2, CV in for SQUARE 2, CV In for BOTH)
PMW Input for OSC 1
PMV Input for OSC 2
SYNC Input for OSC 1
SYNC Input for OSC 2
4 Individual outputs for 4 Sub Oscillators
OSC1 Mix Output
OSC 2 Mix Output
All OSC Mix Output
VCA Output
LFO Output
VCF CV Input
Envelope 1 Gate Input
Envelope 1 CV Output
Envelope 2 Gate Input
Envelope 2 CV Output
VCA CV Input
External Modulation Input
VCF Output
VCA Input
Gate Input for to run 2 Envelopes simultaneously
Master CV input to module everything at once
Master MOD in modulate every parameter at a time.
PMV input to modulate all the PMWs at a time
3x Multiplier Inputs
ebay link : http://www.ebay.de/itm/181134433414?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649
 Filesize:  86.11 KB
 Viewed:  134 Time(s)
 Filesize:  103.83 KB
 Viewed:  120 Time(s)
