  Paulo Santos Synth-ing NºX
Need a saw to squarewave convertor
Page 1 of 1 [3 Posts]
jackdamery
PostPosted: Wed May 08, 2013 6:05 am    Post subject: Need a saw to squarewave convertor Reply with quote  Mark this post and the followings unread
So I have roughly 1v/Octave VCO based from Nicolas's circuit. I would like to convert the saw wave to a square wave so I can have both waveforms. Is there a simple circuit? I imagine a 555 could do the job by tracking the frequency and matching it with a pulse output?
bubzy
Audio files: 63
PostPosted: Wed May 08, 2013 6:29 am    Post subject: Reply with quote  Mark this post and the followings unread
a comparator would do the job for you
http://www.radio-electronics.com/info/circuits/opamp_comparator/op_amp_comparator.php
basically (basically because my understanding is basic), it takes an input voltage, measures that against a reference voltage, and when the input voltage is above the reference voltage, the output is 1 and when it is below the reference voltage, the output is 0. using this method, you can also get some nice PWM from the output, by adding a potentiometer to control the reference voltage.
_Richard_ Smile
Dave Kendall
PostPosted: Wed May 08, 2013 9:03 am    Post subject: Reply with quote  Mark this post and the followings unread
^ what buzby said.
Quite a few VCO designs use a comparator to derive a pulse/square from a TRI or SAW wave - you may find a building block ready to go in online schems for these.
"Everything in moderation, including moderation"
