jfet op amp vs jfet transistor
Page 1 of 1 [2 Posts]
aletropot
PostPosted: Mon May 20, 2013 3:11 pm    Post subject: jfet op amp vs jfet transistor Reply with quote  Mark this post and the followings unread
Hi all,
Someone can explain me what the diference between a jfet op amp and a jfet transistor?
And, why cant use a dual jfet op amp (like tl072) to replace a dual transistor?
Where is my confusion?
Thanks
PostPosted: Mon May 20, 2013 4:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is the inside of an op amp (not a typical one, but one nonetheless Smile ):
Much more complex than a single transistor.
I believe what makes it a JFET Op Amp is the type of transistors used on the inputs. For example 1/4 of an LF444 looks like this:
You can see the JFETs there on the + and - inputs....
