MFOS LFO AND SH101 SUBOSC
Page 1 of 1 [17 Posts]
isak
PostPosted: Sun Jun 23, 2013 1:32 am    Post subject: MFOS LFO AND SH101 SUBOSC Reply with quote  Mark this post and the followings unread
Hi Guys.
those are my layouts for the mentioned in the headline.
they are both verified and working great.
the LFO is from 0.01hrz to 1.43khz
i advice you to use 1M log for the rate pot, its very gentile when turning.
with the log pot is was ok.
for the putout you may use 100k lin.
those are small pcb designs, you can stuff them in addition to any design your making Wink
enjoy.
Isak E.
 Filename:  lfosubosc_126.bmp
 Filesize:  2.77 MB
 Downloaded:  966 Time(s)
tokyomatik
Audio files: 6
PostPosted: Tue Aug 06, 2013 8:11 am    Post subject: Reply with quote  Mark this post and the followings unread
i've just etched and populated the suboscilllator and i really love it
unfortunately i dont get anything from the pulse output but i also dont need it so much. i didnt used a trimmer as u suggested and i didnt found 6.5k resistor but the closest that i had 6.8k worked fine anyway
actually i will use it for the thomas henry xr2206vco
i also added a 100k pot to blend the original signal with the sub.
pretty easy: just connect pin 1 to the original and pin 3 to the sub output; the wiper will be your mixed output
thanks a lot for sharing such an easy but useful layout.
keep up the good work
isak
PostPosted: Tue Aug 06, 2013 8:29 am    Post subject: Reply with quote  Mark this post and the followings unread
thank you.
nice to see that my work is not for nothing Smile
did you tried the LFO as well?
this LFO is great!
tokyomatik
Audio files: 6
PostPosted: Tue Aug 06, 2013 2:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
I will try soon also the lfo, for now i etched already 4 more subosc. pcbs to use for a small analog groove box im building to get the fat bottom i was missing from my square waves
isak
PostPosted: Wed Aug 07, 2013 1:44 am    Post subject: Reply with quote  Mark this post and the followings unread
cool.
enjoy Smile
paulstone
PostPosted: Tue Nov 12, 2013 5:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Isak
thanks for this subosc
ciao
isak
PostPosted: Tue Nov 12, 2013 6:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Your welcome friend Smile
memorygardens
PostPosted: Mon Apr 07, 2014 7:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
has anyone tried the lfo in 15 volts? I want to add it to my motm rig.
isak
PostPosted: Mon Apr 07, 2014 8:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi there.
Works like a charm with 15V without changing nothing.
Enjoy.
Smile
alieneYe
PostPosted: Sun Apr 27, 2014 11:09 am    Post subject: Reply with quote  Mark this post and the followings unread
hello all,
i recently found this. thanks for your work on the layouts. that sub osc is very nice.
i too had problems with the pulse output. i fixed it by inserting an 18K pull-down resistor to the pulse output. now the pulse outputs as well as the other two.
the lfo is nice too.
good work again
T
isak
PostPosted: Sun Apr 27, 2014 11:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi T
its nice to hear that you got the pulse working!
all you did is connecting the output of the pulse to ground through 18k?
cheers
Isak E.
alieneYe
PostPosted: Sun Apr 27, 2014 11:46 am    Post subject: Reply with quote  Mark this post and the followings unread
yes sir. works great
isak
PostPosted: Sun Apr 27, 2014 11:58 am    Post subject: Reply with quote  Mark this post and the followings unread
thank you for this findings.
i never understood why the pulse was not working, maybe i'll remake the board with your 18k resistor.
thank you for your kind words my friend, enjoy the boards.
Isak E.
memorygardens
PostPosted: Wed Oct 01, 2014 12:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
what switch do you recommend? SPDT?
isak
PostPosted: Wed Oct 01, 2014 1:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Smile
If you mean the subosc then yes SPDT is fine.
Enjoy,
Isak E.
memorygardens
PostPosted: Wed Oct 01, 2014 6:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
i mean the lfo. i want it to be a quad lfo in motm format
isak
PostPosted: Wed Oct 01, 2014 11:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
For choosing the waveshapes Youll need spdt.
for the HIGH / LOW you can use spst or spdt.
Enjoy,
Isak E.
