<on air> Twyndyllyngs - Live in person Chez Mosc
Interest in characterized vactrols?
synchroton
PostPosted: Sat Jul 13, 2013 3:50 am    Post subject: Interest in characterized vactrols? Reply with quote  Mark this post and the followings unread
A while back I designed a device to characterize vactrols for on resistance, decay time to 100k, and dark resistance at 10 seconds, for a range of drive currents. I could also modify this to provide resistances at various PWM values at a specified drive current.
I got a bunch of surplus vactrols that I believe were discarded because they're outside of part specs, for a video synthesis project. I'm looking for specific characteristics, and when I'm done distributing these kits, I'm sure there will be a ton left over which fall outside of my own spec. I'm curious if there's interest in the community for a website where you could put in search parameters and have a 'closest match' returned which could be purchased...
It would be a bit of work to go through the effort of putting this together, which is why I'm trying to gauge interest in advance. Please let me know if this would be of use to you, as well as specifically what you're looking for them for. Do you need matched sets? What is the most relevant characteristic for you?
I believe these are silonex vactrols - they are mostly stamped NSL 7053 and some of them bear markings like 'SR3', as in 'NSL-32SR3'
I've also got a quantity of VCL53/2's that could be specified.
