  EdisonRex Edison's Electronic Review (next show Jan 2)
CEM3396 Waveshapers/PWM
Page 1 of 1 [9 Posts]
earo
PostPosted: Tue Jul 30, 2013 6:59 am    Post subject: CEM3396 Waveshapers/PWM Reply with quote  Mark this post and the followings unread
Hello everybody! Smile
I'm trying to build a synth based on the CEM3396.
I'm using a 8038 based VCO to time the CEM, feeding it a +/- 5V square wave, bypassing the datasheet suggested input circuit.
This seems to work, as the DCO follows the VCO.
Most of the CV inputs work great - that is the VCA, VCF and the balance controls.
HOWEVER - the waveshapers (PWM1 & 2 and WS1 &2) do not affect the wave form at all.
Anyone might be able to clue me in as to why this is so? I tried a couple of ICs just to rule out that end, and tried tweaking the clocking square wave down to +/-2.5V as suggested in the datasheet but the wave stays the same.
jackdamery
PostPosted: Thu Aug 01, 2013 12:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey. Looking at the datasheet it seems you feed pin 6 a control voltage on the chip pinout diagram. But then it seems to suggest you apply two logic bits to the base of a transistor between +/- 5v to select the waveforms.
Well anyway as far as I can tell you need to select a sloped waveform before you can apply CV to pin 2 and 10 waveshapers. Can you apply 5v and sweep it via a pot to see if it makes any changes?
earo
PostPosted: Thu Aug 01, 2013 1:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey - Thanks for the input!
I'm actually a little confused as to the function of the Wave Select pin (6).
My understanding was that it is used to select the combination between the two output waves. Wave A only, Wave B only, both or none.
It seems redundant to me considering there's a balance control which allows you mix them freely (minus the 'none' option obviously).
It may very well be that I missed the point of pin 6. I will definitely try what you suggested and report back!
jackdamery
PostPosted: Thu Aug 01, 2013 2:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi I think the wave select pin selects the base waveform - saw, triangle, sawtriangle etc and then the waveshape just affects the actual shape of these. The balance CV (pin 14) swings between the output of the two waves.
It's worth googling the cem3396 as there is quite a bit of info from the community out there.
Here for example:
http://electro-music.com/forum/post-211919.html
Check this too:
http://wolzow.mindworks.ee/analog/m1k.htm
earo
PostPosted: Thu Aug 01, 2013 6:26 am    Post subject: Reply with quote  Mark this post and the followings unread
I tried your suggestion. The wave keeps its triangle shape with a slightly skewed tip. Something must have changed since I last powered this up as the PWM now kills the sound when you start applying it, otherwise the triangle wave stays the same.
Maybe implementing PWM on the driving oscillator will do the trick?
I did Google it, however apart from a couple more posts on EM (which unfortunately didn't address these issues) I couldn't find a whole lot about it.
However, I didn't get a chance to closely study the way the IC was implemented in the Matrix synths - so maybe that should be the next step.
BTW, I tried the little logic circuit suggested in the datasheet. It didn't do anything. Strange chip (or datasheet - or both..) Rolling Eyes
jackdamery
PostPosted: Thu Aug 01, 2013 6:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Well I just received my CEM3396 in the post today so tonight I'll join you in your struggle to find out how the hell it works Smile
earo
PostPosted: Thu Aug 01, 2013 7:18 am    Post subject: Reply with quote  Mark this post and the followings unread
YES! This makes me very happy! We'll get this bugger to do what we want!
There's too much on offer in this chip to give it up!
jackdamery
PostPosted: Thu Aug 01, 2013 7:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Haha yeh, it's really simple in reality. What are you powering it from? +12v and -5v, or +12v and -12v?
earo
PostPosted: Thu Aug 01, 2013 8:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Since I'm using +/-15V for the driving oscillator, LFOs and S/H circuits I have a bunch of regulators going which are putting out +/-5V for CV control (and the negative CEM pin), and a +12V.
I know, I totally went overboard building all these modulators before actually getting the chip to function properly.. I figured I'd be able to use them elsewhere if all fails... but yes, it did seem very unlikely since the CEM seems very straight forward.
BTW, I'm feeding the second clock input a divided square wave for sub oscillation, white noise seems to work too!
Once this waveshaping business is sorted out I expect this to be a pretty powerful mono synth! Cool
