  Paulo Santos Synth-ing NºX
XR2206 VCO tri/sine troubles!!
Page 1 of 1 [2 Posts]
tokyomatik
Audio files: 6
PostPosted: Tue Jul 30, 2013 10:02 pm    Post subject: XR2206 VCO tri/sine troubles!!
Subject description: sine looks like a square??
hi guys! i finish to build an 2206 vco and the sine is kind of strange.
is more than the double in amplitude respect the triangle and it looks like a square wave a bit rounded, im trying to fix it with symmetry and round trimmers but i dont see good results.
the triangle instead has a little spike / imperfection similar to the 4046... nothing too bad.
the square is ok.
i didnt used an lf442 but i already placed an order. at the moment i have an LM358...could be the reason?
im also not really sure about the wiring of the switch, i didnt found any drawing about it...anyone??
i also still have to wire the skew parts but i dont think this could be the cause.... Question
tokyomatik
Audio files: 6
PostPosted: Fri Aug 09, 2013 3:04 am    Post subject: Reply with quote  Mark this post and the followings unread
well i swapped the lm358 with an lf442and the result still the same...at this point i will try one by one all the xr2206 that i've in stock and if also this doesnt help....Ahhhhhhhhhhhhhhhhh
i will tKE A PICTURE OF THE BOARD...MAYBE IT WILL ALSO HELP
