<on air> Muied Lumens Frequencies
Add LEDs to envelope generators
Page 1 of 1 [5 Posts]
abelovesfun
PostPosted: Mon Aug 05, 2013 11:47 am    Post subject: Add LEDs to envelope generators Reply with quote  Mark this post and the followings unread
Hello,
I have built two MFOS envelope generators and would love to add an LED to each to show the envelope output.
I thought the best way would be to incorporate this circuit:
http://www.musicfromouterspace.com/analogsynth_new/SOUNDLABMINISYNTH/soundlabmods/soundlabmods.html#LEDINDICATORS
Where the output was tapped instead of an IC.
Of course, these circuits use +/- 12v. Can I just use a resistor to draw some current from the 12 volt (3.33 Ohms) and then the 1k to the LED?
Experimental and modular music at: https://soundcloud.com/she-suburban-heroin-electronics
I make Eurorack DIY Kits (pcb and or panels also available): aisynthesis.com
the19thbear
PostPosted: Mon Aug 05, 2013 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Im in the same situation Smile
PostPosted: Mon Aug 05, 2013 8:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would just use a 1.2k or 1.5K resistor--whatever you would use if you just wanted to hook the resistor and the LED to power and ground. No need for multiple resistors.. I would expect it ought to work fine. Transistor LED buffers are pretty common.
sonicwarrior
PostPosted: Tue Aug 27, 2013 6:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Yep, I used a transistor based LED driver on my MFOS ADSR, too, but it runs with +/- 15V. I think I used 1K there.
abelovesfun
PostPosted: Mon Sep 02, 2013 8:43 am    Post subject: Reply with quote  Mark this post and the followings unread
I did it and it worked for me - used a 1.5k resistor from the 12v supply.
Video is up here: http://www.youtube.com/watch?v=60zO0kyPWZs
Blink - Blink - Blink!
