<on air> electro-music.com June Solstice Concert Various artists
ARP Odyssey Whiteface Power light substitute? LED?
adhmzaiusz
PostPosted: Tue Aug 27, 2013 8:16 pm    Post subject: ARP Odyssey Whiteface Power light substitute? LED? Reply with quote  Mark this post and the followings unread
Sorry if it's a noobish question (I'm good at soldering and replacing parts but not the theory behind how things work)
This ARP odyssey I'm restoring seems to use a mini AC light bulb in the switch which has burned out. By the look of the schematic it has about a 100k resistor only between the bulb and the AC lines. Nothing else, so this bulb must be running right off of 115v.
Question is this: Anyone have a recommended bulb replacement type to lookout for at the nearest electronics shop, or is there a very easy way to sub an LED in there from the AC line? Not sure if an LED would work without an extra circuit of somesort since it is a diode and the lamp is AC...
Any help would be great! The more I learn the better. Just finished rigging this thing from 220V to 120V and am really pumped to get it in tip top shape.
www.myspace.com/adhmzaiusz
