 Forum index » Discussion » Introduce Yourself
Hi i am new here
Page 1 of 1 [5 Posts]
01012k7
PostPosted: Sat Aug 31, 2013 4:00 am    Post subject: Hi i am new here
Subject description: new member
Hi I decided to signup here because I am in to electronic synthesiser projects and electronic music I like almost all music ...
I been building electronic projects for about 18 months, I do built a lot of analog synths projects I am not great at electronic but i have a desire to improve also some of the projects I have build I should not have started because they are above my knowledge but they do end up working unless I forgot to wire the output sockets ..
Embarassed
I make a lot of PCB using the transfer paper method also print front panel using the same method also vinyl printing too.
P.S I will post some pictures of projects... Very Happy
PostPosted: Sat Aug 31, 2013 4:05 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome I suspect that you will be able to increase your knowledge here.
Steve
PostPosted: Sat Aug 31, 2013 9:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello 01012k7. Welcome to the forums. We talked a while ago about the Korg Monotron. How is that project coming along? I have been meaning to do an online tutorial explaining it better and giving some improved options, but I have been ill and not able to do it. Hopefully I can get around to it soon. I will post it here on the forums when it is completed.
JacobWatters.com
01012k7
PostPosted: Sat Aug 31, 2013 12:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
not done much with the project to be totally honest sort did not understand that well but I want to get it done before Christmas ...also been very busy with other projects that were easier for me to build
pcb boards did not turn out as well as I would have liked but they not been tested ...
 Filesize:  682.62 KB
 Viewed:  61 Time(s)
front panel with Korg Monotron will be installed
 Filesize:  865.29 KB
 Viewed:  55 Time(s)
Ok made this from 19mm oak flooring also made the switches for the keys
 Filesize:  603.73 KB
 Viewed:  58 Time(s)
Oh this my big project which I made over 30+ boards also the keyboard was taken from old midi keyboard which has been change to switches not shure if it will work :)
 Filesize:  1.29 MB
 Viewed:  61 Time(s)
01012k7
PostPosted: Sun Oct 13, 2013 11:52 am    Post subject: Reply with quote  Mark this post and the followings unread
ok started working on this project again first thing I did was buy a metal bender as I decided to make a metal case with oak sides also going to be installing a simple 8 step basic analog sequencer also maybe with the option of having cv and gate inputs ...
