 Forum index » DIY Hardware and Software » The Repair Shop
Casio cz line out question
Page 1 of 1 [5 Posts]
9 volts
PostPosted: Sat Sep 07, 2013 5:10 am    Post subject: Casio cz line out question Reply with quote  Mark this post and the followings unread
Hi there, I need to fix the Line out on my casio cz101. It has a faulty relay switch. Does anyone know if I can just bypass this? I figure it my be difficult to find a replacement. Schematic is online. Thanks again
PostPosted: Sat Sep 07, 2013 5:34 am    Post subject: Reply with quote  Mark this post and the followings unread
I know this has been discussed in one of the Casio CZ Yahoo! Groups forums. Some replacement options might even be mentioned. http://launch.groups.yahoo.com/group/CZsynth/
Steve
9 volts
PostPosted: Sat Sep 07, 2013 6:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Great thanks, just had a look at yahoo. Looks like a common problem. Have still not found any info on replacement (will keep searching). From what I have read a bypass is ok. Thanks
DES
PostPosted: Sat Sep 07, 2013 6:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Just be careful that your sound system volume is down when you turn the CZ on if you bypass it. The relay keeps the initial 'pop' from turning the unit on from getting to the output. Later synths used FETs to do something similar. I would think a substitute for the relay could be found...just make sure the coil voltage and current requirements are correct.
www.davesneed.com
9 volts
PostPosted: Sun Sep 08, 2013 4:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, I managed to fix the old relay. Someone had bent a switch and jammed it. So the other switch could not rise and fall. Thanks again
