Hold key missing
Page 1 of 1 [3 Posts]
schaltstern
PostPosted: Thu Oct 17, 2013 12:54 pm    Post subject: Hold key missing Reply with quote  Mark this post and the followings unread
the A6 doesn't seem to have a hold key (except for the ribbon). Is there a fast and easy way to achieve that without using a foot controller?
Thx,
Dirk
sunny pedaal
Audio files: 12
PostPosted: Sat Oct 19, 2013 9:18 am    Post subject: Reply with quote  Mark this post and the followings unread
take a footswitch with latch mode
( the footswitch supplied with the a6 is momentary, only holds as long as you press it, in latch mode ones it holds till pressed again. i have one from boss, but any pedal will do )
other solution is turn the release to max.
however don't forget to turn it back before changing a prest or notes will hung
schaltstern
PostPosted: Sun Oct 20, 2013 7:11 am    Post subject: Reply with quote  Mark this post and the followings unread
yes, I use a foot switch now (your A6 came with a foot switch? mine didn't IIRC).
Thanks for the suggestions.
