  Various Artists Live streaming concert in memory of Antimon
(untested) frequency doublers
Page 1 of 1 [2 Posts]
commathe
PostPosted: Thu Oct 24, 2013 2:36 am    Post subject: (untested) frequency doublers Reply with quote  Mark this post and the followings unread
Came up with this the other day after playing around with a leading edge detector. Basically, square wave is run through a high-pass/differentiator and then that is rectified and put through a buffer.
Definitely won't yield a 50% duty cycle square wave apart from at a narrow band of frequencies - and there will be a frequency above which it will stop working (as you approach the pass-band of the filter).
Without the buffer, they can also be a sort of square to saw converters, also octave up - though that's at a limited range of frequencies again
Replace the resistor in the high-pass filter to tune it.
 Filesize:  16.58 KB
 Viewed:  70 Time(s)
commathe
PostPosted: Thu Oct 24, 2013 4:15 am    Post subject: Reply with quote  Mark this post and the followings unread
I had posted an op-amp version but it is not showing Sad
 Filesize:  24.09 KB
 Viewed:  67 Time(s)
