manual gate
Page 1 of 1 [6 Posts]
flab
PostPosted: Fri Oct 25, 2013 6:13 am    Post subject: manual gate Reply with quote  Mark this post and the followings unread
hello everyone ,
well im thinking of making a really easy module for a couple of manual gates ,
like here at doephers diy page, so what im thinking to do is replace the res.(470Ω) with a pot (10kΩ) ,makes scene ? and please can you make clear how to add sustain , with a cap maybe ?
thanks in advance
 Filesize:  1.98 KB
 Viewed:  1279 Time(s)
Bogus Noise
PostPosted: Fri Oct 25, 2013 6:29 am    Post subject: Reply with quote  Mark this post and the followings unread
You might need to look into debouncing to get a cleaner start to the gate.
Also, I think rather than replacing the 470 resistor, you'd want to put a pot as an attenuator/voltage divider in between the resistor and the output, it'd be similar to the simple attenuator also on the Doepfer DIY page.
The capacitor would add a release stage rather than sustain. Are you wanting the gate to stay on for a set amount of time?
Circuit Bent Sonic Absurdity:
www.bogus-noise.co.uk
http://www.youtube.com/user/BogusNoise
flab
PostPosted: Fri Oct 25, 2013 6:55 am    Post subject: Reply with quote  Mark this post and the followings unread
release suits me more ,yep thats what im looking for, so im placing a cap thats suits me before led and after the switch, so far so good
Bogus Noise
PostPosted: Fri Oct 25, 2013 6:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, cool. Yeah for that kind of thing you need a diode, followed by a cap (something like 2uF) to ground parallel with a variable resistor (maybe a 4.7k resistor in series with a 1M pot) to ground.
corex
PostPosted: Mon Oct 28, 2013 3:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
I made a similar kind of module, posted the schematic in this other thread:
http://electro-music.com/forum/post-386912.html#386912
Maybe interesting to you (or maybe too complex).
flab
PostPosted: Mon Oct 28, 2013 4:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks corex ,
thats really nice, is just few cmos , ill be alright
but probably a dual versionof that as a i have onlyone 4013 at my drawer
i really like that switch there
