VCO Modulation
Page 1 of 1 [24 Posts]
isak
PostPosted: Fri Oct 25, 2013 11:29 pm    Post subject:  VCO Modulation Reply with quote  Mark this post and the followings unread
Hi guys.
need help with in wiring Embarassed
building a new synth and i want the ability to send one LFO to the 2 vco's separately and together, meaning...
using on-off-on toggle switch:
left side "ON" will be VCO 1
right side "ON" will be VCO 2
center "OFF" will be VCO 1 and 2.
is it possible to do?
i was stayed up late trying to drew this but didnt got to any solutions.
if you guys have any idea of how to do it i'll be happy to hear, as long as its with 3way toggle switch.
attached is the basic idea.
the buffer is for the 2 vco's from one LFO.
cheers.
Isak E.
 Filesize:  22.25 KB
 Viewed:  52 Time(s)
analogmonster
PostPosted: Fri Oct 25, 2013 11:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
As you can't route a signal thru an "off" position directly you need additional logic like electronic switches driven by the "on" positions and an inverter in the "off" case.
Easier way would be to use a three position rotary switch Razz
Regards
Carsten
http://www.analog-monster.de/index_en.html
isak
PostPosted: Sat Oct 26, 2013 12:15 am    Post subject: Reply with quote  Mark this post and the followings unread
I though it would be the answer.
I don't have space for additional rotary switch.
gdavis
PostPosted: Sat Oct 26, 2013 9:22 am    Post subject: Reply with quote  Mark this post and the followings unread
This is my circuit to do exactly what you're talking about, not fully tested yet though.
Replace R5 and the circuit to the left of it with your LFO output.
SEL_A and SEL_B are connected to each end lug of the switch, center lug is connected to ground.
When the panel switch is open, R6 and R7 pull up the control inputs to turn on the LFO to the VCO's. When the switch is closed one way or the other, that control input is grounded turning off the LFO to the corresponding VCO.
 Filesize:  17.99 KB
 Viewed:  57 Time(s)
thermionicjunky
PostPosted: Sat Oct 26, 2013 8:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
You can wire up a C&K 7211 DPDT as an on-on-on with one position connected to VCO 1, another to VCO 2 and the third to both. A diagram can be found here:
http://www.simple-answer.com/DIY.html
Broadwave
Audio files: 6
PostPosted: Sun Oct 27, 2013 12:07 am    Post subject: Reply with quote  Mark this post and the followings unread
...or try a 2P3T switch.
Centre position = Mod to both VCO's
Left Position = Mod to VCO 1
Right Position = Mod to VCO2
The problem is getting hold of a 2P3T toggle switch - I've only seen them in slide (eg. Fender Mustang Switch)
 Filesize:  56.87 KB
 Viewed:  9039 Time(s)
Broadwave
Audio files: 6
PostPosted: Sun Oct 27, 2013 12:31 am    Post subject: Reply with quote  Mark this post and the followings unread
I didn't quite understand the diagram at first, but there's a simple slide show explaining it here :
http://www.youtube.com/watch?v=14i2B8scNaI
If only I'd known about this before I ordered a bunch of rather expensive Fender 2P3T switches Rolling Eyes
isak
PostPosted: Sun Oct 27, 2013 5:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks guys.
Even after seen the tube vid I don't understand the logic of it Embarassed Confused
I see it is a regular on off on switch, it's the wiring and the outputs I don't understand..
EDIT:
Ok, so if I understadnd this correctly by the tube vid..
A is down
C is up
B is center
gdavis
PostPosted: Sun Oct 27, 2013 10:58 am    Post subject: Reply with quote  Mark this post and the followings unread
That's actually not quite what you need. It connects "common" to one of three different points. Though I guess you could connect "center" to both VCO's to get what you want, but this might be a little cleaner:
 Filesize:  10.62 KB
 Viewed:  8932 Time(s)
isak
PostPosted: Sun Oct 27, 2013 1:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Now I understand what I don't understand.
As I see the layout you show me is on on on, the red lines are changing by the switch position, the blue line is a jumper, till here I'm ok.
In the on off on switch I don't get the red lines like in the on on on switch.
This is got me confused.
I see that when the on on on switch is in center position it shorts from the upper right to center and the lower left to center which I don't get in the on off on switch.
I guess the conclusion is I will need an on on on switch and can't do this with on off on switch, right?
PostPosted: Sun Oct 27, 2013 6:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think the point is that the on-on-on switch would be more straightforward (once you wrap your head around it--a tough job, it took me a while too). You can use on-off-on, but you'll have to add additional logic and something like a 4066 switch to route the signals the way you have stated, whereas with the on-on-on it's just a wiring exercise. A tricky one, but still you basically just wire your inputs to the right places, and a common to the next stage, and you're done.
Here's Scott Stites' version of explaining the switch, you may find it easier to follow. As someone else already said, you could wire it so that each VCO was connected to one 'side' of the switch, and the center position would combine them--assuming you had summing resistors before the switch.
http://www.birthofasynth.com/Thomas_Henry/Images/SN-Voice_construction/c&k7211_3way.jpg
Edit: I'd wire VCO1 to pin 3, VCO2 to pin 4, wire 5 & 2 together and run them to the thing that was taking the sum (likely an op amp). Or maybe reverse pins 3 & 4 if I got the direction of the switch wrong Very Happy
isak
PostPosted: Mon Oct 28, 2013 7:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, all the time I was thinking they takes about the on off on switch, this I why I got confused.
Now its all clear to me Smile
Any source to the on on on switch?
All I find in eBay is the on off on, not on on on.
Cheers.
PostPosted: Mon Oct 28, 2013 9:25 am    Post subject: Reply with quote  Mark this post and the followings unread
I bought some from Mouser....
isak
PostPosted: Mon Oct 28, 2013 11:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
The problem with mouser is the expensive shipping.
If you don't make a BIG buy it's not worth the shipping.
PostPosted: Tue Oct 29, 2013 4:48 am    Post subject: Reply with quote  Mark this post and the followings unread
I would imagine there are other sources, but I'm at a point where EBay is last resort, because I've been burned and hear too many bad stories.
isak
PostPosted: Tue Oct 29, 2013 5:38 am    Post subject: Reply with quote  Mark this post and the followings unread
its depends, you need to know from who to buy.
i have my my fav shops, only from there im ordering, never failed me.
i ordered some TL074 from unknown source and got burned so i know what your talking about.
Sebo
PostPosted: Thu Oct 31, 2013 8:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi:
May be you can try a circuit like the one used in panpots.
Connect the LFO to both VCOs throught a resistor, then use a common on-off-on switch, extreme pins conected to VCO mod inputs after de resistor, and middle pin connected to ground. So when the switch is in the middle both VCOs have the LFO modulation, when you move the switch to one side, the input goes to ground and that VCO will have no modulation.
Sebo
My Music:
www.cosaquitosenglobo.com.ar
isak
PostPosted: Thu Oct 31, 2013 12:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Sebo.
You got me confused.. Confused
Any pic to follow your description?
Sebo
PostPosted: Thu Oct 31, 2013 1:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Something like this:
 Filesize:  3.63 KB
 Viewed:  8438 Time(s)
Sebo
My Music:
isak
PostPosted: Thu Oct 31, 2013 3:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the scheme Sebo!
As I understand it's not an DPDT switch?
What would be the appropriate values of R1,2,3,4? 1k for each one will be ok?
Last question...
I see what you mean by center position will be both vco's.
But if I'm not mistaken when the switch position will be up for example one path will be passing smoothly, the second path will short with ground but part of it wouldn't go to the vco? I'm asking cause eventually I see it's connected to the vco through a resistor but still connected.
Sebo
PostPosted: Thu Oct 31, 2013 4:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
The switch is a common on-off-on switch.
The values for R1, R2, R3 & R4 depends on the value of the input resistor of the VCO CV summing network. Usually this resistor is 100K. You have to remove the original resitor and use R3/R4 instead. In that case a good value will be 51K for all resistors. If you don't want to remove the resistor on the VCO, ommit R3 & R4 and try a small value for R1 & R2, something like 10K will work (I think), but the modulation deep will be a little less than normal...
Sebo
My Music:
isak
PostPosted: Thu Oct 31, 2013 11:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, now after sleeping all make sence to me.
Yes, I'll remove the 100k from the vco's.
The only thing I'm nor sure about is how/where to connect the 100k amount pot.
I think I'll put it from the LFO out before going to the switch.
like the attached pic, what do you think?
Thanks Sebo.
 Filesize:  4.86 KB
 Viewed:  8325 Time(s)
Sebo
PostPosted: Fri Nov 01, 2013 10:50 am    Post subject: Reply with quote  Mark this post and the followings unread
That's right.
Sebo
My Music:
isak
PostPosted: Fri Nov 01, 2013 12:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cheers man Smile
