<on air> Currently on the open port test
  Various Artists electro-music.com March Equinox Concert
  Twyndyllyngs Live Chez Mosc
Replacing faulty NM1 Potis
Page 1 of 1 [2 Posts]
m:o
PostPosted: Wed Oct 30, 2013 2:09 am    Post subject: Replacing faulty NM1 Potis Reply with quote  Mark this post and the followings unread
some Pots on my NM1 failed, sending random values to the editor, and have to be replaced. Has anyone did this? I need some infos mainlyabout the desired spare potis and maybe some hints about possible problems i can run into. i have some basic soldering skills so i'm not worried too much.
thx
Vader77
PostPosted: Sat Dec 07, 2013 4:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Deoxits the best to clean tho applying to much can dissolve the grease on the shaft and take away that smoothness which is exactly what happened with mine. I'm planning to take all of them apart and apply some tonearm damping grease when I get time. Failing that they are exactly the same knobs found in the other early nord leads which are still around and I've read they are the same size as some regular pot that just requires a little filing down.
