Feifer
Posted: Sun Nov 10, 2013 3:28 pm Post subject:
4040 troubles |
Hi all,
I'm having problems with this chip and was hoping someone out there could help me out. For some reason timing diagrams are hard to come by in data sheets for this chip. The only one I could find was for the MC14040, which jameco says is the same thing. http://www.jameco.com/Jameco/Products/ProdDS/12950MOT.pdf
The way I have it set up is since it triggers on a falling edge, I have my clock pulses going through an inverter. So when the clock is off, the input is held high. I have a push button going from V+ to reset and when I push it, all Qs go low, as they should. The problem is when I release it, Q1 goes high, which, according to the timing diagram it shouldn't do until the input goes low. Is the CD4040 set up slightly different? Any way I could get around this?
Thanks |
Feifer
Posted: Sun Nov 10, 2013 5:45 pm Post subject:
Okay. For a stupid little chip with only 2 inputs, this gremlin is being really hard to track down. I put it back on the bread board and it works just fine. I put it in the socket on the pcb (exact same circuit) and it does it's weird game. Ready to throw this thing at the wall. |
Posted: Mon Nov 11, 2013 7:58 am Post subject:
Does your clocking source have some bounce in it? Breadboards have lots of extra capacitance, perhaps that's filtering out some stray glitches that your PCB is seeing?
I'd try putting a cap on the input, something like the RC Debouncer shown in this doc:
http://www.eng.utah.edu/~cs5780/debouncing.pdf |
Feifer
Posted: Mon Nov 11, 2013 1:11 pm Post subject:
Well I found the culprit. I had a capacitor on the reset input tied to V+ meant to initialize the chip upon power up. Not entirely necessary but a nice little feature. Why it was working on the breadboard but not on the pcb I have no idea. |
