  Various Artists June Solstice live streaming concert
Some major updates
Page 1 of 1 [2 Posts]
Audio files: 218
G2 patch files: 319
PostPosted: Fri Nov 22, 2013 7:03 pm    Post subject: Some major updates Reply with quote  Mark this post and the followings unread
Some major updates .. for the whole story and downloads see http://bluehell.electro-music.com/modules/
Some highlights :
I renamed the thing to 'Wren', also it will now read and write .wren files instead om .mpatch files - although the mpatch ones are still fine to be read in. (and wren files can be posted here)
made some fixes to the scrollbox so it won't add space above modules anymore.
Fixed the text edits so the DEL key can be used without crashing the thing.
Changed the tuning from linear to exponential, it is a 0.1 Units / Octave thing now. This was done to keep signals around the range [-1,1] a bit (that range gives about 22 octaves now). One alternative would have been to use Clavia units ... which means 1 Units / Octave, but also means a dynamic range for signals of [-256,256], which would mean a lot of changes to have attenuators and scalers and logic (to name a few) to still make sense, signal level wise.
Changed the knob scaling so that TET values like 440 Hz can actually be dialed in.
Changed the scaling for LFOs such that it maps the Clavia LFOs better (so I can use LFOs for tempo stuff on both and have it at about the same speed).
Changed the status from pre-alpha to alpha.
Audio files: 218
G2 patch files: 319
PostPosted: Sat Nov 23, 2013 4:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
It still needed a little work here and there, but with what I did today I was able to actually run my first noodle thingie Exclamation
Anyways, there is a version 2013.11.23.3 available now at http://bluehell.electro-music.com/modules/
Made a lil demo recording (attached) with this patch:
