<on air> Various Artists Live streaming concert in memory of Antimon
anybody able to ID this PCB?
Page 1 of 1 [9 Posts]
new voodoo
PostPosted: Sat Nov 30, 2013 5:25 pm    Post subject: anybody able to ID this PCB? Reply with quote  Mark this post and the followings unread
I know its a filter, but I cant remember anything else and I have NO idea where I put all the info that was with it. I just found it in a pile and started populating it cause I had a few minutes and thought "why not--i think it might go in this other thing over here or maybe with this doohicky over there"
and then after id done the ICs..kinda figured out I had NO idea what it was exacty..and theres NOTHING written on it other than a couple numbers which turn out to be unrelated.
im sure someone knows what it is? Maybe we can think of it as a 'challenging new game of figure out 'what the hell he's found in his pile of junk today'"
www.newvoodoodesign.com
-my creations, bends & bendable pieces
-vintage parts & tubes, IC's & audio chips
-oddities & weird
newvoodoo.blogspot.com
-bending DIY/projects
-crap
new voodoo
PostPosted: Sat Nov 30, 2013 5:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
pics
 Filesize:  318.83 KB
 Viewed:  82 Time(s)
 Filesize:  207.63 KB
 Viewed:  179 Time(s)
-oddities & weird
-crap
Bogus Noise
PostPosted: Sun Dec 01, 2013 12:23 am    Post subject: Reply with quote  Mark this post and the followings unread
I can't make it out, but have you Googled that code on the middle left of the second pic?
Circuit Bent Sonic Absurdity:
www.bogus-noise.co.uk
http://www.youtube.com/user/BogusNoise
new voodoo
PostPosted: Sun Dec 01, 2013 5:22 am    Post subject: Reply with quote  Mark this post and the followings unread
yep thats the numnbers i was referring to..apparentlt just refers to the blank perfboard or whatever[right]
thank yoou though, appreciate it.[/right]
-oddities & weird
-crap
PostPosted: Sun Dec 01, 2013 8:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Maybe try googling the components to find a BOM?
Is there any particular component that's more unusual? i.e. if it's a filter, is it made with the typical SSM2164 or LM13700, or is it something more esoteric?
emmaker
PostPosted: Sun Dec 01, 2013 1:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yaaa, Don't you love hobby electronics.
moogah SEM VCF
I was just going thru my board backlog today and have it on my desk.
OK, I work in electronics and when I find stuff like this I just bang my head against the wall. Here are some of the issues I see with the board. I've worked in electronics long enough I can handle all these. And if I need good test or rework equipment I can just take things to work and do them.
* No board name or rev number.
* Values on the board silk screen vs. designators. Great when you assemble it, bad when you have to debug/fix it or values change.
* Small pads which require good soldering equipment which most hobbyists don't have to pull/change parts.
Good luck.
Jay S.
mcop
PostPosted: Mon Dec 02, 2013 1:24 am    Post subject: Reply with quote  Mark this post and the followings unread
It is indeed the Mooghah SEM filter board. If you are going to build it be sure to read the thread on Muffs first as it can be built in two different ways - with and without voltage controlled resonance. Certain components are only needed depending on which build you go for. Also one of the transistors is silk screened the wrong way round on the board.
Built mine a while ago with voltage controlled resonance and love it although it still has a few minor issues to be sorted. Been having to much fun using it to get round to that yet Very Happy
http://www.muffwiggler.com/forum/topic-82093.html
new voodoo
PostPosted: Sun Dec 15, 2013 12:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
yep it is and thanks to everyone.
And yes, I DID read the thread.
WOW, if id known all the problems id never have gotten on it, but ill soldier thru.
Just FYI for anyone else getting it-PM me if you do as there are QUITE a few unlabeled, poorly labeled, wrong way-facing, unnecessary SMD pads, etc issues and ive made a list from the forum thread so I can be sure and check them all off when finishing.
-oddities & weird
-crap
new voodoo
PostPosted: Sun Dec 15, 2013 12:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
moogah SEM VCF
Good luck.
Jay S.
Yea, I do mostly custom guitars but I also do a good bit of circuit bending and trading/selling in a VERY minor way (imagine an online version of a table at a swap meet)..that said, id have NEVER put this out BUT Id also say at the same time-its probably (and I dnt know the person in the slightest) smeone also doing it very small time and perhaps its their first project or they are very young and got excited and focused on the finish line and not the details (which can, admittedly, REALLY get you in electronics)
-oddities & weird
-crap
