NO MIDI OUTPUT FROM A6
Page 1 of 1 [4 Posts]
saktronica
PostPosted: Sun Dec 22, 2013 7:39 pm    Post subject: NO MIDI OUTPUT FROM A6 Reply with quote  Mark this post and the followings unread
Hello Guys,
I have an Alesis Andromeda A6. I'm trying to use it as a synthesizer and a midi controller to play my vst's to conserve space in my studio. I purchased a midi interface and for some reason the andromeda is not transmitting any midi output because the midi interface isn't picking up on the signal. Is there a setting on the Andromeda that will allow the keyboard to transmit midi output.
saktronica
PostPosted: Sun Dec 22, 2013 8:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello Guys any suggestions? Is there a midi out switch that will allow me to connect my a6 to a midi interface that connects to my computer via usb that will allow me to use A6 as a midi controller? Please somebody help me I'm having a hard time with
soundwave106
PostPosted: Mon Dec 23, 2013 11:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Hit Global for the global menu settings.
"TXMode" should be set to either MIDI (transmit only, no local sounds) or "LOCMIDI" (play both MIDI notes and local sounds). "LOCAL" disables MIDI output, possibly your keyboard is set to that.
Also make sure the MIDI channel is correct, that's also in the first global menu page.
saktronica
PostPosted: Mon Dec 23, 2013 7:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks bro I got it to work!
