Dual-VCOs and Dual-OTAs
Page 1 of 1 [6 Posts]
Boerge
PostPosted: Sun Jan 05, 2014 4:57 am    Post subject: Dual-VCOs and Dual-OTAs Reply with quote  Mark this post and the followings unread
Hi @all and happy new year!
New year, new projects Wink
I am thinking about a dual VCO like the one in the Moog Taurus. It uses CA3080, what would happen if one replaces them by a LM13700? Would there be any bleedthrough from one VCO to the other or something like syncing? Or would it work without any problems?
regards
Boerge, whose 13key-pedal is screaming for a use...
...ich will doch nur löten...
andrewF
PostPosted: Sat Jan 18, 2014 6:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have built several modules where the 13700s are shared by different circuits and have never noticed any bleed or other interaction between the two sections. None of these were VCOs tho, but VCFs, VCAs and VC-LFOs.
Make sure the chip has decoupling caps close to the power pins.
new voodoo
PostPosted: Sat Jan 18, 2014 7:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
i wuldnt worry abt that. im sure therell b other things tho
www.newvoodoodesign.com
-my creations, bends & bendable pieces
-vintage parts & tubes, IC's & audio chips
-oddities & weird
newvoodoo.blogspot.com
-bending DIY/projects
-crap
Boerge
PostPosted: Tue Jan 21, 2014 7:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for your replies.
Too late, I'm already soldering Wink Maybe I tell later, what happens.
Boer-"Which side of the iron is hot?"-ge
mistercooper
PostPosted: Sat Feb 08, 2014 7:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Please do. Smile
bod
PostPosted: Mon Feb 10, 2014 6:06 am    Post subject: Reply with quote  Mark this post and the followings unread
i use an LM13700 for a VCO and VCA in my wee drum/dub siren circuits and its works great without any bleed through Smile
