  Various Artists June Solstice live streaming concert
Sequencer pulse width
Page 1 of 1 [7 Posts]
anclib
PostPosted: Wed Jan 22, 2014 10:18 am    Post subject: Sequencer pulse width Reply with quote  Mark this post and the followings unread
Hi, does anyone know of a circuit for altering the pulse width of a sequencer's steps? preferably something simple and without comparators, could a 555 could be used maybe, or is there something even simpler?
J3RK
PostPosted: Wed Jan 22, 2014 10:59 am    Post subject: Reply with quote  Mark this post and the followings unread
You could make a simple gate to trigger converter using a couple of resistors and a capacitor and a diode. (I'll see if I can draw one or find an image.) This would be just a very short pulse/spike though, so if you just wanted a short full gate signal, you might want to try something else.
You could trigger a monostable (which a 555 can be set up as). There are some CMOS monostable chips as well, and you can also build one with a couple of transistors a cap and some resistors. Look up transistor monostable.
I have a sequencer design that uses a series of flip flops to drive some counters and a multiplexer. I wanted to shorten the individual gate outputs, so I used 8 AND gates, and ANDed the gate outputs with a signal from one of the flip flops, which cut the gate lengths in half. This sort of approach would depend on how your sequencer is driven/clocked though. Just pointing out that there are quite a few ways you might do this.
This may be helpful: http://www.electronics-tutorials.ws/waveforms/monostable.html
anclib
PostPosted: Wed Jan 22, 2014 11:13 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks, my sequencer is just a simple shift register type with the 555 clock, so the register is just detecting the rises in the 555 input pulse. I was thinking maybe of a envelope instead of gate length but its probably a little to complicated and would cause attenuation problems in the cv output.
ryktnk
PostPosted: Thu Jan 23, 2014 1:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello
The easiest way is starting with a sawtooth vco and slicing ( sorry comparator )
the waveform.
Check out Renne's 4069 VCO, it is a one chip solution.
-ryk
roglok
PostPosted: Thu Jan 23, 2014 4:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
you also might want to check out ian fritz's delayed pulser:
http://electro-music.com/forum/post-151463.html#151463
anclib
PostPosted: Sun Jan 26, 2014 10:57 am    Post subject: midi to gate circuit Reply with quote  Mark this post and the followings unread
Hi thanks for your helpful replies, it much appreciated.
Hello, does anyone know of a circuit for simple inexpensive midi to gate,
I am not interested in midi to CV, just the gate so I can sync analogue sequencer.
Ideally something that is very cheap and easy that I can put together myself.
isak
PostPosted: Tue Jan 28, 2014 2:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
You can do it with arduino, it's cheap and easy to make.
I just need to remember where I put the code Rolling Eyes
