A new book by Thomas Henry - The PICAXE 18M2 Cookbook!
Page 1 of 1 [3 Posts]
Tim Servo
PostPosted: Sat Jan 25, 2014 12:57 am    Post subject: A new book by Thomas Henry - The PICAXE 18M2 Cookbook!
Subject description: Slightly OT?
Announcing a new book by Thomas Henry - THE PICAXE 18M2 COOKBOOK!! A great introduction to using and programming the PICAXE Microcontroller, this book covers a wide range of topics in an easy to read step-by-step guide. Available this Sunday (Jan 26th) from the Magic Smoke Electronics print to order service at:
www.lulu.com/spotlight/magsmoke
 Filesize:  2.54 MB
 Viewed:  144 Time(s)
Tim Servo
PostPosted: Sat Jan 25, 2014 1:04 am    Post subject: A new book by Thomas Henry - The PICAXE 18M2 Cookbook! Reply with quote  Mark this post and the followings unread
I've been working with Thomas for a while, helping to prepare his latest book. Although there are some fun musically oriented projects included, this book is a more comprehensive guide for using and programming the PICAXE 18M2. The book includes a range of projects covering topics like output displays, digital input, analog I/O, DC and stepper motor control, an infrared transmitter, external eeprom, MIDI I/O, and more. Here's the official blurb:
"The revolution in low-cost microcontrollers has enabled DIY enthusiasts to create projects they never could have pulled off before. But the devices can be intimidating and frustrating to use, especially for newcomers. Expensive prototyping and programming systems, difficult programming languages, and hard to decipher data sheets have kept many from using these modern miracles. Until now. DIY Guru, Thomas Henry has done the research, and brings you this step-by-step guide on programming and building your own useful circuits and projects with the PICAXE 18M2 Microcontroller. Using standard, readily available components, and programming in an easy-to-learn BASIC language, this book presents a comprehensive guide to getting digital power into your next project."
This volume includes:
-- 56 projects
-- 66 photographs
-- 62 schematics
-- 56 programs
-- 214 pages
Tim Servo
PostPosted: Sat Jan 25, 2014 1:08 am    Post subject: Reply with quote  Mark this post and the followings unread
And for those of you looking for a Table of Contents:
CHAPTER 1 FIRST STEPS
WHAT’S INSIDE THE PICAXE 18M2?
PLAN OF ATTACK
OVERVIEW OF THE PROGRAMMING PROCESS
A FEW WORDS ABOUT THE PINS
SOME HARDWARE CONSIDERATIONS
WHAT ABOUT THE VARIABLES?
CHAPTER 2 OUTPUT DISPLAYS
PROJECT 1: SERIAL OUTPUT TO A PC
PROJECT 2: LIGHT AN LED
PROJECT 3: LED DIMMER
PROJECT 4: BICOLOR LED
PROJECT 5: TRICOLOR LED — I
PROJECT 6: TRICOLOR LED — II
PROJECT 7: TRICOLOR LED — III
PROJECT 8: TEN-STAGE LED DOT DISPLAY — I
PROJECT 9: TEN-STAGE LED DOT DISPLAY — II
PROJECT 10: TEN-STAGE LED DOT DISPLAY — III
PROJECT 11: TEN-STAGE LED BAR GRAPH — I
PROJECT 12: TEN-STAGE LED BAR GRAPH — II
PROJECT 13: DIRECT 7-SEGMENT DISPLAY
PROJECT 14: MULTIPLEXED TWO-DIGIT 7-SEGMENT DISPLAY
PROJECT 15: LATCHED TWO-DIGIT 7-SEGMENT DISPLAY
PROJECT 16: SERIAL TWO-DIGIT 7-SEGMENT DISPLAY
PROJECT 17: QUAD 7-SEGMENT DISPLAY
PROJECT 18: INCANDESCENT LIGHT BULB
PROJECT 19: PARALLEL DATA LCD
CHAPTER 3 DIGITAL INPUT
PROJECT 20: SPST SWITCH
PROJECT 21: CENTER-OFF TOGGLE SWITCH
PROJECT 22: DIGITAL JOYSTICK
PROJECT 23: BINARY SWITCH
PROJECT 24: FOUR-BIT GRAY ENCODER
PROJECT 25: MATRIX KEYPAD
PROJECT 26: SLOTTED OPTO SWITCH
PROJECT 27: TOUCH SWITCH
PROJECT 28: INFRARED REMOTE CONTROL
PROJECT 29: HANDCLAP SWITCH
PROJECT 30: 60HZ TIMEBASE
CHAPTER 4 ANALOG INPUT
PROJECT 31: POTENTIOMETERS
PROJECT 32: CADMIUM SULPHIDE LIGHT SENSOR
PROJECT 33: HOMEBREW PRESSURE SENSOR
PROJECT 34: TEMPERATURE SENSOR
PROJECT 35: ENVELOPE AMPLITUDE DETECTOR
CHAPTER 5 ANALOG OUTPUT
PROJECT 36: THREE-BIT DAC
PROJECT 37: FOUR-BIT DAC
PROJECT 38: FIVE-BIT DAC
PROJECT 39: PRECISION 7-BIT DAC
PROJECT 40: THREE OPTIONS FOR AUDIO OUTPUT
PROJECT 41: EASY DRUM VOICE
CHAPTER 6 MOTOR CONTROL
PROJECT 42: DC MOTOR SPEED CONTROL
PROJECT 43: DC MOTOR DIRECTION CONTROL–I
PROJECT 44: DC MOTOR DIRECTION CONTROL–II
PROJECT 45: UNIPOLAR STEPPER MOTOR CONTROL
PROJECT 46: BIPOLAR STEPPER MOTOR CONTROL
CHAPTER 7 ODDS AND ENDS
PROJECT 47: INFRARED TRANSMITTER
PROJECT 48: RESET SWITCH
PROJECT 49: LOW VOLTAGE ANALOG SWITCH
PROJECT 50: BIPOLAR ANALOG SWITCH
PROJECT 51: ADJUSTING THE INTERNAL CLOCK FREQUENCY
PROJECT 52: INTERNAL SR LATCH
PROJECT 53: I2C DATA EEPROM
PROJECT 54: MIDI OUTPUT
PROJECT 55: MIDI INPUT
PROJECT 56: ULTRASONIC RANGING DEVICE
RESOURCES
