DUBmatze
Joined: Feb 18, 2013 Posts: 150 Location: south Germaica (schwabilon)
Posted: Wed Feb 05, 2014 11:44 am Post subject:
the CMOS dub drum |
iam close to my 3rd year in the electronic dungeon now...
(i learn the most in this forum, thank you Lunetta heads,very special ty phobos)
here is my new CMOS "drum". nice for dubbing. i used an old joystick out of a Playstation One controller.
the drum is only half ready - but cant finish it iam so happy with testing.
iam starting now some quick recordings... |
DUBmatze
Posted: Wed Feb 05, 2014 12:28 pm Post subject:
and a quick recording:
(needs better echo..)
Audio files: 705
commathe
Posted: Wed Feb 05, 2014 5:49 pm Post subject:
Would putting a pot between the 10u cap to ground and ground change the decay possibly? Maybe you could use a smaller cap and a pot? This is sheer guesswork tough |
DUBmatze
Posted: Thu Feb 06, 2014 3:22 am Post subject:
PHOBoS wrote: | Nice one! took me a couple minutes to figure out you put a VCA at the end | thank you. i found evrything in the lunettaforum for this. (cant find the original "vca" thread at the moment - think the post was from the mister with the Leonard Nimoy avatar - not shure)
PHOBoS wrote: | Did you need the extra diode on the output to get it silent ? A capacitor would make more sense, | you right. a cap works mutch better. I use the diode because my passiv mixer behind was a bit confuse the circuit.
commathe wrote: | Would putting a pot between the 10u cap to ground and ground change the decay possibly? Maybe you could use a smaller cap and a pot? | yes the cap is the "decay" adding a pot is also possible. (i was trying but the 10k from joystick are not handy, maybe a 50k+ pot) smaller cap is no problem only biger. the output of the 4050 cant charge caps biger than arround ~13u or so. maybe the other 5 stages of the 4050 in parallel or some kind of transitor and a BIG Cap and a big pot to get a range like the DS7 / DS8 clones got.
Wile building this i think a lot of a DS Clone in CMOS (cheap and easy). I got some ideas:
- adding more sense to the piezo will be possible by adding a R ladder and some diodes using 2 ore more 4050stages at the input (hit soft, midle, hit hard ... or just get an "accent") -> this stages carges the decaycap less ore more ... OR affect the CV for the vco
- adding a LFO. simple just a smittosc at the cv input of the 4046. Sweep is also easy just a filter on the LFO signal. But mixing the values from lfodeep, sweep, oscfreq into a single CV for the 4046 -> there will be no "lunettaway" and no way for me atm. (i have to google OP amp voltage summing .... or so .. )
you see there is room for a rev 2,3,4, mk 2, 3 ... hehe |
DUBmatze
Posted: Thu Feb 06, 2014 4:13 am Post subject:
DUBmatze wrote: | (cant find the original "vca" thread at the moment - think the post was from the mister with the Leonard Nimoy avatar - not shure) | found it:
http://electro-music.com/forum/topic-23960.html&postorder=asc
it was richardc64. also a great thank you to richardc64. |
Audio files: 705
Posted: Thu Feb 06, 2014 7:48 am Post subject:
ah, smoking spock (he is smoking right ?) I can never argue with anything he says just because of that avatar alone (and he seems to be correct)
I'm not sure if I saw that thread before, but I used a similar VCA in the Moon Base Xplorer and used it to create a voltage controlled mixer, it works great
for such a simple circuit. _________________ "My perf, it's full of holes!"
richardc64
Audio files: 26
analog_backlash
Joined: Sep 04, 2012 Posts: 393 Location: Aldershot, UK
Audio files: 21
Posted: Thu Feb 06, 2014 6:03 pm Post subject:
At the risk of putting a dampener on the proceedings, Spock has COPD:
http://www.bbc.co.uk/news/entertainment-arts-26064849
I'm not a anti-tobacco fiend, BTW - I wish that I could give it up myself and spend my money on something more useful. I'm on the patches at the moment, with variable success .
Gary |
analog_backlash
Audio files: 21
Posted: Fri Feb 07, 2014 4:35 am Post subject:
Hi DUBmatze.
I didn't get a chance to listen to it last night, so I didn't make any comments about it. I have now and it sounds really good . I like the combination of the piezo and the joystick (I haven't seen that before). I see that you're also using ExpressSCH now, which I do also (when I can be bothered...).
Keep up the good work!
Gary |
DUBmatze
Posted: Fri Feb 07, 2014 1:03 pm Post subject:
Thank you richand and gary,
when this is a voltage doubler is the firt cap behind the 4050 in wrong direction? (i found both directions when i google "voltage doubler")
Yes the expressSCH is a nice tool. I think i stay at this. making Costom componets is easy, its free and the export to emf is cool. so i can beaty them up in inkscape. i wish i have the font from it as .ttf or so. need to make a PCB soon - and give this a try...
i working to improve the Joystick controll at the moment. i have atm pitch (Y) and decay (X) and i think i put the "slide" on the push butten in the joystick. at the moment is my 2,5 years old sohn is drumming on the piezo with a huuuuuge (2B) drumstick. |
richardc64
Audio files: 26
