the CMOS dub drum
Page 1 of 1 [12 Posts]
DUBmatze
PostPosted: Wed Feb 05, 2014 11:44 am    Post subject: the CMOS dub drum Reply with quote  Mark this post and the followings unread
iam close to my 3rd year in the electronic dungeon now...
(i learn the most in this forum, thank you Lunetta heads,very special ty phobos)
here is my new CMOS "drum". nice for dubbing. i used an old joystick out of a Playstation One controller.
the drum is only half ready - but cant finish it iam so happy with testing. Wink
salut happy smoker bounce salut
iam starting now some quick recordings...
DUBmatze
PostPosted: Wed Feb 05, 2014 12:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
and a quick recording:
(needs better echo..)
Audio files: 574
PostPosted: Wed Feb 05, 2014 2:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice one! took me a couple minutes to figure out you put a VCA at the end Very Happy
Did you need the extra diode on the output to get it silent ? A capacitor would
make more sense, but it sounds like it's working great as it is.
SoundCloud BandCamp Stickney Synthyards Captain Collider
commathe
PostPosted: Wed Feb 05, 2014 5:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Would putting a pot between the 10u cap to ground and ground change the decay possibly? Maybe you could use a smaller cap and a pot? This is sheer guesswork tough
DUBmatze
PostPosted: Thu Feb 06, 2014 3:22 am    Post subject: Reply with quote  Mark this post and the followings unread
thank you. i found evrything in the lunettaforum for this. (cant find the original "vca" thread at the moment - think the post was from the mister with the Leonard Nimoy avatar - not shure)
Did you need the extra diode on the output to get it silent ? A capacitor would make more sense,
you right. a cap works mutch better. I use the diode because my passiv mixer behind was a bit confuse the circuit.
yes the cap is the "decay" adding a pot is also possible. (i was trying but the 10k from joystick are not handy, maybe a 50k+ pot) smaller cap is no problem only biger. the output of the 4050 cant charge caps biger than arround ~13u or so. maybe the other 5 stages of the 4050 in parallel or some kind of transitor and a BIG Cap and a big pot to get a range like the DS7 / DS8 clones got.
Wile building this i think a lot of a DS Clone in CMOS (cheap and easy). I got some ideas:
- adding more sense to the piezo will be possible by adding a R ladder and some diodes using 2 ore more 4050stages at the input (hit soft, midle, hit hard ... or just get an "accent") -> this stages carges the decaycap less ore more ... OR affect the CV for the vco
- adding a LFO. simple just a smittosc at the cv input of the 4046. Sweep is also easy just a filter on the LFO signal. But mixing the values from lfodeep, sweep, oscfreq into a single CV for the 4046 -> there will be no "lunettaway" and no way for me atm. (i have to google OP amp voltage summing .... or so .. )
you see there is room for a rev 2,3,4, mk 2, 3 ... hehe
DUBmatze
PostPosted: Thu Feb 06, 2014 4:13 am    Post subject: Reply with quote  Mark this post and the followings unread
found it:
http://electro-music.com/forum/topic-23960.html&postorder=asc
it was richardc64. also a great thank you to richardc64.
Audio files: 574
PostPosted: Thu Feb 06, 2014 7:48 am    Post subject: Reply with quote  Mark this post and the followings unread
ah, smoking spock (he is smoking right ?) I can never argue with anything he says just because of that avatar alone Wink (and he seems to be correct)
I'm not sure if I saw that thread before, but I used a similar VCA in the Moon Base Xplorer and used it to create a voltage controlled mixer, it works great
for such a simple circuit.
richardc64
Audio files: 26
PostPosted: Thu Feb 06, 2014 10:35 am    Post subject: Reply with quote  Mark this post and the followings unread
You're welcome, DUBmatze. No problemo. Interesting piezo interface, and I like the voltage-doubler E.G.
I've noticed that in some situations the second diode -- the one at the output -- is necessary, at other times only a cap is needed. Never figured out what conditions apply. Ken Stone's Chime Simulator, for example, leaves out the output diode.
http://www.cgs.synth.net/modules/cgs19_chime.html
Thanks, PHOBoS. Here's the full Spock pic. Several possible captions come to mind.
 Filesize:  25.03 KB
 Viewed:  4495 Time(s)
"I’m a New Yorker, and I know a con when I see one.” -- Michael Bloomberg
analog_backlash
Audio files: 21
PostPosted: Thu Feb 06, 2014 6:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
At the risk of putting a dampener on the proceedings, Spock has COPD:
http://www.bbc.co.uk/news/entertainment-arts-26064849
I'm not a anti-tobacco fiend, BTW - I wish that I could give it up myself and spend my money on something more useful. I'm on the patches at the moment, with variable success Wink .
Gary
analog_backlash
Audio files: 21
PostPosted: Fri Feb 07, 2014 4:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi DUBmatze.
I didn't get a chance to listen to it last night, so I didn't make any comments about it. I have now and it sounds really good Very Happy . I like the combination of the piezo and the joystick (I haven't seen that before). I see that you're also using ExpressSCH now, which I do also (when I can be bothered...).
Keep up the good work!
Gary
DUBmatze
PostPosted: Fri Feb 07, 2014 1:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you richand and gary,
when this is a voltage doubler is the firt cap behind the 4050 in wrong direction? (i found both directions when i google "voltage doubler")
Yes the expressSCH is a nice tool. I think i stay at this. making Costom componets is easy, its free and the export to emf is cool. so i can beaty them up in inkscape. Wink i wish i have the font from it as .ttf or so. need to make a PCB soon - and give this a try...
i working to improve the Joystick controll at the moment. i have atm pitch (Y) and decay (X) and i think i put the "slide" on the push butten in the joystick. at the moment is my 2,5 years old sohn is drumming on the piezo with a huuuuuge (2B) drumstick.
richardc64
Audio files: 26
PostPosted: Fri Feb 07, 2014 2:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm...I'm seeing it both ways too. For an envelope, I let the PAiA StringzNThingz be my guide: + end of the cap goes to the trigger source.
Triggers enter at K37. PSB = Piano Sustain (actually decay,) Bus. MXP = mixer
 Filesize:  7.18 KB
 Viewed:  4219 Time(s)
