  Antimon Antimon Waves
a simple question about inversion and polarity.
Page 1 of 1 [4 Posts]
blinky_Palermo
PostPosted: Sat Feb 08, 2014 12:07 am    Post subject: a simple question about inversion and polarity. Reply with quote  Mark this post and the followings unread
i'm working on a vactrol-based circuit running on a bipolar power supply.
the goal is to use an incoming signal to power two LEDs with inverse relationships to each other.
the incoming signal is full-wave rectified, so it is operating on a 0 to 12v range. if i invert that through an inverting op amp, i get a 0 to -12v range.
what i want is a 12v to 0v-going voltage, while the other voltage is going from
0v to 12v, if that makes sense.
any advice would be appreciated. thanks!
analogmonster
PostPosted: Sat Feb 08, 2014 3:34 am    Post subject: Re: a simple question about inversion and polarity. Reply with quote  Mark this post and the followings unread
Add +12 V to the output of your inverter stage you mentioned above?
blinky_Palermo
PostPosted: Sat Feb 08, 2014 5:19 am    Post subject: Reply with quote  Mark this post and the followings unread
well, that makes sense. i'm not sure why it evaded me. thanks!
JingleJoe
PostPosted: Sun Feb 09, 2014 12:29 am    Post subject: Reply with quote  Mark this post and the followings unread
in the past I've used a simple transistor inverter (google that) with a pnp transistor, 1 meg resistor on the base and 4k7 on the collector going to +V. you loose a bit of signal at one end (because of the forward voltage of the transistor) but it does the job if you don't need precision.
