  Muied Lumens Frequencies
Bringing a pin LOW with a squarewave LFO?
Page 1 of 1 [3 Posts]
commathe
PostPosted: Sun Feb 23, 2014 10:07 pm    Post subject: Bringing a pin LOW with a squarewave LFO? Reply with quote  Mark this post and the followings unread
Hey guys, I've been working on a guitar stompbox but this digital logic problem seems to suit here best.
I am using a chip (HT8950) that has two pins I want to hit with a square wave LFO to modulate the effect. There a problem I can't get around though: the pins have internal pull-ups and need to be brought LOW to trigger the effect. This has kind of thrown a wrench in the works for me as I don't know how to achieve this. I thought of using a JFET to sink the current from the pin to ground and using that to pull it low but I haven't been able to get it work.
Surely a few of you must have tricks up your sleeves?
elektrouwe
PostPosted: Mon Feb 24, 2014 3:26 am    Post subject: Re: Bringing a pin LOW with a squarewave LFO? Reply with quote  Mark this post and the followings unread
commathe wrote:
... need to be brought LOW to trigger...
a Schottky-diode (Vforward<=0.3V) with cathode towards the LFO should do the job. GNDs of LFO andHT8950 connected. If you don't have one, any NPN with emitter grounded and collector pulling down the HT-input, and 10k from LFO to base should also work.
commathe
PostPosted: Tue Feb 25, 2014 12:03 am    Post subject: Reply with quote  Mark this post and the followings unread
I like the NPN idea! Thanks! It's funny because I was already using NPNs to drive LEDs as rate indicators but didn't think about using them to pull the pins low. Will definitely try it out!
