<on air> Modulator ESP Adventures In Sound
Simple but fun bleepy machine
Page 3 of 3 [54 Posts]
Goto page: Previous 1, 2, 3
jclassic1
PostPosted: Sun Apr 14, 2019 9:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Right,got it now,that does make sense as far as mounting the board.
Thank you once again for your help.
John
Audio files: 644
PostPosted: Sun Apr 14, 2019 10:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Actually they should be facing downwards Embarassed , otherwise the components would get in the way if you mount it behond a panel.
This also seems to be correct if I compare the layout with he schematic.
jclassic1
PostPosted: Mon Apr 15, 2019 12:46 am    Post subject: Reply with quote  Mark this post and the followings unread
OK thanks,facing down it is then.
John
jclassic1
PostPosted: Fri May 17, 2019 2:21 am    Post subject: Reply with quote  Mark this post and the followings unread
It took me a couple of tries to get it working probably due to my not so good soldering skills but it does now work and makes some quite interesting sounds.
I am not planning to mount this in a box as of yet but now I am looking at what I can build to go with this bleepy machine.
It seems most people favor a sequencer so I will look for a simple beginner friendly sequencer on these forum sites.
It has been fun and a bit frustrating to build this and I am just pleased that I actually got it to work.
John
