<on air> PHOBoS presents: Smokers Delight (light em up!)
Mars Equinox signup thread
Page 2 of 3 [61 Posts]
Audio files: 263
PostPosted: Wed Mar 19, 2014 9:02 am    Post subject: Reply with quote  Mark this post and the followings unread
ah a break in the line-up (at least for now). Maybe I'll do a martian spring filler or we could do a jam if anyone is up for it Very Happy
martian music jam sounds fun Smile
Audio files: 562
PostPosted: Wed Mar 19, 2014 10:00 am    Post subject: Reply with quote  Mark this post and the followings unread
shanemorris wrote:
I like Mars Laughing
yeah, Mars rocks!
SoundCloud BandCamp AcidTrasH Stickney Synthyards
PostPosted: Wed Mar 19, 2014 2:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
I haven't had the energy to plan a set, but I would love to join in in some jamming with the Martians! Smile Martian Art! cyclops
Ganzha
Audio files: 27
PostPosted: Thu Mar 20, 2014 2:33 am    Post subject: Reply with quote  Mark this post and the followings unread
No banner yet?
http://ziart.kz
Audio files: 31
PostPosted: Thu Mar 20, 2014 5:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Muied Lumens wrote:
As you can see, there is a break in the middle (at least for now). People will be able to perform in this slot, but only if they are able to do so without a radio operator to sit in during this time. You should know how to connect using sc_trans if you are interested in this. This is an experimental test for events of this kind, to see if in future events we can maybe make do with less ops.
I am streaming with BUTT. Will that work or do I have to download sc_trans? If "yes", then what version of sc_trans should I use. Is it hard to learn?
Thanks for the info and thank you for the opportunity to perform. I'm going to check my schedule and may opt to do a second thirty-minute set during the break if I can get up and running with sc_trans.
Audio files: 346
PostPosted: Thu Mar 20, 2014 5:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Then you are already set up for it. In practical terms you just connect using a different port and this also means that when you start streaming you go directly on air, nobody has to switch you.
However, if a jam happens, somebody could pick up your private port and mix it with others, so there would be no need to change anything in your BUTT setup. Jams are usually organzed on the spot in the chat room.
A poster will be coming later today from me, but anyone who feels they want to make one is free to do so. Smile
Muied Lumens Base Star
Audio files: 346
PostPosted: Thu Mar 20, 2014 11:25 am    Post subject: Reply with quote  Mark this post and the followings unread
The poster is added to the first post in this thread.
Parityflux
PostPosted: Thu Mar 20, 2014 11:40 am    Post subject: stream test ok Reply with quote  Mark this post and the followings unread
OK, I tested my connection with some help from the lads in the chat room. All is well. For the show, do I get a different port (I used 8130 to test), or is there a specific one I need to be ready to go in prior to show time. How soon before show should I connect? details details. I'm looking forward to this.
-John
PS: After trying many stream clients I ended up with an ASIO version of Edcast. I really wanted to use BUTT because I like the interface a little better, but it wouldn't allow access to other channels of my interface. I think it was just targeting the Windows WDM channels.
Audio files: 346
PostPosted: Thu Mar 20, 2014 11:52 am    Post subject: Re: stream test ok Reply with quote  Mark this post and the followings unread
5-10 minutes before you go on air is good. If you want to test earlier than that, before you go on air, this should be ok too, but check in the chat first. You will be told in chat when you are actually on air. Note: there is an average delay of 30 or so seconds before people hear what you are broadcasting, so it can be useful to start ahead, or have a "start" sound/drone which can act as an introduction as you are waiting for the go signal.
Looking forward to hearing your set. Smile
mtvic
PostPosted: Thu Mar 20, 2014 12:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
I will test my port Friday 3/21
anyone known what port
Audio files: 346
PostPosted: Thu Mar 20, 2014 12:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is a quick port assignment for those who need it:
Ganzha: - - - - - - - - Port 8130
Michael Victor (mtvic) - - - Port 8132
SPGoodman - - - - - Port 8134
Parityflux - - - - - Port 8130
That should do it for now - we will have an events page set up on the wiki soon.
mtvic
PostPosted: Thu Mar 20, 2014 12:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
May I use this sound in my stream on Saturday?
http://www.space.com/17110-screaming-down-to-mars-how-curiosity-s-descent-sounded-video.html
Audio files: 346
PostPosted: Thu Mar 20, 2014 1:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
I can't tell you that. Laughing
You will have to find out if the sound is in the public domain or if it is copyrighted somehow.
Audio files: 216
G2 patch files: 319
PostPosted: Thu Mar 20, 2014 1:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
For port assignments please see the event page in the wiki.
There is one day left to test your ports, please go and earn yourself a dot on the event page!
And there is some more readworthy info in the wiki radio pages.
Audio files: 216
G2 patch files: 319
PostPosted: Fri Mar 21, 2014 12:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
As you may have noticed we will have a planned server outage in about four hours ... please test your ports ...
Audio files: 263
PostPosted: Sat Mar 22, 2014 8:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's my setup for my performance and the jam if it happens
Nord G2 into 18 second loop for granular stuff and ipads/op-1 into 16 second loop, for some nicely shifting cosmic noise droning Very Happy
darkvortex
Radio Master
PostPosted: Sat Mar 22, 2014 8:57 am    Post subject: Reply with quote  Mark this post and the followings unread
My mini rig for the Mars Equinox 2014 event. All software plus the Novation Launchkey Mini controller.
Joel's mini rig
 Filesize:  174.96 KB
 Viewed:  290 Time(s)
mtvic
PostPosted: Sat Mar 22, 2014 12:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great Fun today
Thank you for the opportunity of the extended time .
and the compliments.
Phobos please let me know if you have a recording of my extended set .
I started at about 15:40 or so.
Audio files: 346
PostPosted: Sat Mar 22, 2014 2:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's a quick hack of the poster to make a banner...
 Filesize:  266.31 KB
 Viewed:  181 Time(s)
Jack_Hertz
Audio files: 112
G2 patch files: 6
PostPosted: Sat Mar 22, 2014 5:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is the last hour and some of the Mars Break Jam recorded 2014 - 03 - 22. Participants include: PHOBoS, Modulator ESP, Jack Hertz, Blue Hell, and Antimon
Jack Hertz.com | Aural Films | Encyclotronic
Audio files: 216
G2 patch files: 319
PostPosted: Sat Mar 22, 2014 6:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
It is not possible currently to upload sets .. there is a wrong PHP setting still after the server switch.
This will be fixed after the event finished, as it needs a a service restart which would interrupt the streaming.
Sorry for that, may the patience be with you Cool
PostPosted: Sun Mar 23, 2014 4:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Had a good time listening, great stuff all around! Thanks all streamers, operators and Muied Lumiens for kickstarting and organising! thumleft well done
Audio files: 562
PostPosted: Sun Mar 23, 2014 5:40 am    Post subject: Reply with quote  Mark this post and the followings unread
pm sent Cool
Audio files: 346
PostPosted: Sun Mar 23, 2014 6:09 am    Post subject: Reply with quote  Mark this post and the followings unread
It was Kevin Kissinger who kickstarted me! Laughing
It was an amazing event and I'm so glad I got the opportunity to hear most of the music live. Thank you kindly to everyone who signed up, opped, played and listened.
Audio files: 263
PostPosted: Sun Mar 23, 2014 8:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Any chance you could let us know when upload is fixed please Smile
