 Forum index » How-tos
what header connector is this what voltages for Euro Rack
Page 1 of 1 [4 Posts]
buildafriend
PostPosted: Fri Mar 14, 2014 11:51 am    Post subject: what header connector is this what voltages for Euro Rack
Subject description: I'm trying to find the part so that I can design a PSU PCB
Hi, I recently got a bubble sound VCOb and I want to build a power supply for it. im electronics savvy but I am newer to the synth world so I don't know the standards. I was wondering what might be the standard voltages that come from a eurorack PSU.. are they +/-12v, 0V, GND, and +5v? an overlook at a stadard eurorack PSU card would be very nice to look at. I'm also not sure what size/style header is used as the standard to connect these euro modules to the power supply. If I knew, then I could start designing a foot print or find a pre made one in my component library.
thanks regardless team. keep it weird.
buildafriend
PostPosted: Fri Mar 14, 2014 11:55 am    Post subject: Reply with quote  Mark this post and the followings unread
I think I might have found some answers here..
http://www.dintree.com/#D112
adnauseam
PostPosted: Fri Mar 14, 2014 12:28 pm    Post subject: Eurorack Standards.. Reply with quote  Mark this post and the followings unread
Eurorack standards follow the standards created by Doepfer for the A-100 modulars in the earlier days.
You can find the standards here
Analog solutions follows a slightly different PSU header that doesn't have +5 volts and I believe it's a 10 pin connector vs the Doepfer 16.
buildafriend
PostPosted: Sat Mar 15, 2014 5:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks very much! lots of great information in that link.
