Posted: Sat Apr 12, 2014 4:23 am Post subject:
High resolution encoders |
Bear in mind that I'm not as electronics-savvy as most here, so be gentle on me.
I like the concept of endless encoders, I have a BCR2000 which I think is kind of brilliant. What I would like to have though, is a BCR2000 which isn't limited by the MIDI resolution. The encoders on the BCR will go from 0 to 127 on a full turn. I would like an encoder to go from, say, 0 to 65535 (16 bits) instead, on a full turn.
It is true that the BCR actually supports 16 bit (or is it 14 bit) numbers, but using a greater range like that doesn't improve the resolution on the knob, it just means that you can keep turning past 127 and the value will keep going higher. I don't want to have to turn like a madman to reach a higher value.
So is it possible to find parts to build such a thing? I guess what I want is basically a monome arc without the fancy looks and huge knobs. I just want to try a knob, however basic, that will let me feel an instant and precise response when I turn it. Plus I have to be able to get it to send values into a computer somehow (if I wanted to make a DIY analog I could just use any old pot).
Any ideas, hints or preferences? Maybe there already is such a thing to be found somewhere?
I admit I haven't started looking at parts sites yet, I figured there's probably someone here that can give me a good starting point. _________________ Antimon's Window
Joined: Dec 11, 2010 Posts: 966 Location: Toronto, Ontario - Canada
Posted: Sat Apr 12, 2014 9:05 am Post subject:
You need to consider what you will be using the encoder to control. The resolution of the encoder is irrelevant if you are sending the reading as MIDI data because you will still be limited to either 7 or 14 bits.
If you are not using MIDI, then what is the protocol you are using and how will the computer interpret it? What app/vst is the final destination and what type and resolution of data will it accept? |
Posted: Sat Apr 12, 2014 10:24 am Post subject:
Yeah maybe I should have been clearer. I want to control programs I write myself on a computer. I'd like to use ChucK, if possible. ChucK can talk OSC and also (after the most recent release) some kind of serial protocol. It could also work using compound MIDI messages with high and low bytes transmitted one after the other somehow. _________________ Antimon's Window
Joined: Apr 03, 2004 Posts: 24075 Location: The Netherlands, Enschede
Audio files: 277
Posted: Sat Apr 12, 2014 1:04 pm Post subject:
Your best bet would bee something like how a mouse works .. when you move it slowly it can be pixel precise, and when you move it faster it will skip steps.
A rotary with 2^16 steps .. if you could find it you would not want to pay what it costs and even if you did .. it would be impossible probably to move it that precise.
When you have a controller going 0 - 127 already it would be cool if it would wrap then at the end .. you could then implement a mouse like algorith yourself .. but prolly not eh ... so .. arduino time I guess!
32 step rotarries can be found pretty cheap, and this may just be enough if you add some clever coding. _________________ Jan
