<on air> Twyndyllyngs Live Chez Mosc
Stereo samples
Page 1 of 1 [5 Posts]
sorenkj
PostPosted: Thu May 01, 2014 9:35 am    Post subject: Stereo samples
Subject description: Bug?
How do you play stereo samples? According to the documentation (http://chuck.cs.princeton.edu/doc/language/ugen.html#chan) I think the following should work, but the sample seems to get mixed down to mono.
Code:
SndBuf s;
me.sourceDir() + "/stereosample.wav" => s.read;
s => dac;
while(true) 1::ms => now;
I also tried the following but then no sound is heard at all.
Code:
SndBuf s;
s.chan(0) => dac.left;
s.chan(1) => dac.right;
PostPosted: Fri May 02, 2014 3:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Weird. Have you tried using dac.chan(0) and dac.chan(1) instead of .left and .right, just to check? I'm not by my computer right now, but I can have a quick look when I get home later.
sorenkj
PostPosted: Fri May 02, 2014 4:07 am    Post subject: Reply with quote  Mark this post and the followings unread
yes, tried that as well.. maybe this is another problem with Windows or my computer only.. (like this one - http://electro-music.com/forum/topic-61748.html)
Samu
PostPosted: Sun Aug 03, 2014 1:31 am    Post subject: Re: Stereo samples
Code:
SndBuf s;
s => dac;
Code:
SndBuf s;
To get stereo you need to use SndBuf2.
eg
Code:
SndBuf2 s;
s => dac;
Then it won't be mixed down to mono, was having the same problem last week!
sorenkj
PostPosted: Mon Sep 01, 2014 5:02 am    Post subject: Reply with quote  Mark this post and the followings unread
ah..! thanks for the tip:)
