Vst/Au 32/64 bit versions for Win/OSX/Linux?
Page 1 of 1 [8 Posts]
alfonso
PostPosted: Wed Jun 18, 2014 6:01 am    Post subject: Vst/Au 32/64 bit versions for Win/OSX/Linux? Reply with quote  Mark this post and the followings unread
very good stuff here!
would be great to integrate it in a DAW enviroment with all the automation facilities!
congrats!
a.
Audio files: 218
G2 patch files: 319
PostPosted: Mon Jun 23, 2014 3:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ow .. missed this one Shocked
Not sure about the DAW bit .. I mean, I can see how it would add value .. it is just that I don't use a DAW myself, and neither am very likely to do so soon ...
forcefielder
PostPosted: Tue Jan 06, 2015 9:04 am    Post subject: Reply with quote  Mark this post and the followings unread
will wren work in older versions of windows? I'm thinking of installing xp on my mac.
Audio files: 218
G2 patch files: 319
PostPosted: Tue Jan 06, 2015 1:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
It should work in XP, but I have no XP anymore to test it on.
PostPosted: Fri Jan 09, 2015 5:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have played a little with wren in a 32 bit XP PC (approx. 10 years old, I think).
HrastProgrammer
Audio files: 73
PostPosted: Sun Jan 11, 2015 2:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, it worked on XP/32 here as well.
http://www.hrastprogrammer.com/hrastwerk/
http://hrastprogrammer.bandcamp.com/
calande
PostPosted: Sun May 03, 2015 4:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, the VSTi feature is almost a requirement. That would save the hassle of having to load the synth manually, load the patches manually and keep it in the background while Cubase is running. A VSTi is so convenient (e.g. the KarmaFX Modular synth VSTi vs. the Nord Virtual Modular), you can even manage conveniently several tracks assigned to several instances of the modular synth, with the knobs always at the right settings, the right patch preloaded for each track, as soon as you load your Cubase project file. It saves so much time and hassle Cool
alfonso
PostPosted: Mon Jul 04, 2016 4:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah i think a VSTi/VST fx version would be a great milestone for WREN.
It would increase a lot the user base and can have an iteresting commercial appeal too if you want to integrate it with the open source model.
