Where can I find info on speech synthesizers?
Page 1 of 1 [12 Posts]
AlessandroS
PostPosted: Sun Jul 27, 2014 10:02 pm    Post subject:  Where can I find info on speech synthesizers? Reply with quote  Mark this post and the followings unread
Hi everyone,
I went to the Ontario Science Center and found this exhibit. http://www.dse.nl/~evoluon/coffee.htm
It was very cool and fun, and I started looking for similar synthesizers/modules that I could make. Nothing yet, but perhaps you can help me. If you know of something that operates on the same concept, please let me know.
Thank you!
Audio files: 705
PostPosted: Mon Jul 28, 2014 4:30 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome party!
well there is GinSing an arduino shield which uses a Babblebot chip,
Cantarino, a software speech synthesiser for Arduino which doesn't need an extra shield.
And the SpeakJet chip which is used in this synth module.
I don't have any personal experience with any of them btw Rolling Eyes
AlessandroS
PostPosted: Mon Jul 28, 2014 7:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the links. I'm looking for something free of software, as I read somewhere that the "Coffee Machine" was made entirely of discrete components. Elsewhere, someone told me that likely what was happening was similar to Bell Labs' VODER in 1939, where noise is filtered to make fricatives and plosives, and a sawtooth or square wave is filtered to make vowel sounds.
Any idea how I could find that information, and how to sequence it? I would love to be able to make different words by rearranging modules or cables.
Audio files: 705
PostPosted: Mon Jul 28, 2014 9:02 am    Post subject: Reply with quote  Mark this post and the followings unread
I haven't fully read it yet but this seems useful: Synth Secrets, Part 23: Formant Synthesis
AlessandroS
PostPosted: Mon Jul 28, 2014 12:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's helpful, but it doesn't give me any idea on how to start design, and doesn't cover consonant sounds. I'll keep looking, and I've contacted the science center to see if they have any schematics, since they apparently did repairs on it at some time before the 90s, after Evoluon had given it to them.
andrewF
PostPosted: Tue Aug 12, 2014 5:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
here's one from Jaski 1963
tube based voice synth with relays and inductors....just FYI Very Happy
 Filesize:  62.74 KB
 Viewed:  146 Time(s)
Dave Kendall
PostPosted: Fri Aug 15, 2014 1:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Jim Patchell designed a vocal formant filter PCB, and Fonik built one from Jim's posted files. I believe it's voltage controllable, which gets you a little further along the way towards good control, and AFAIK the design doesn't use any rare ICs.
I don't have a link, but search here or on muffwiggler and you should find something.
"Everything in moderation, including moderation"
andrewF
PostPosted: Fri Aug 15, 2014 5:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have built two of these on Jim's PCBs, the 2nd one (for someone else) sounded amazing, my one seems to have an issue somewhere. Definitely vocal like sounds but no speech synthesizer.
Anyway, they use CA3280s, quite a few of them.
I also built a redesign of the Ai Cybernetic model 1000 Speech synth, details are here -
http://www.sdiy.org/pinky/data/bindubba4.html
I should point out the filter needs work....another project i should re-visit one day Rolling Eyes
The original manual is here -
http://www.hartetechnologies.com/manuals/Unclassified/AI_Cybernetics_Model_1000_Speech_Synthesizer_M.PDF
schematic on pgs 41 & 43
and let's not forget the VOSIM
http://www.sdiy.org/pinky/vosim/vosim.html
donpachi
PostPosted: Sat Aug 16, 2014 3:34 am    Post subject: Reply with quote  Mark this post and the followings unread
I'll add the Chatterbox
http://yusynth.net/archives/WirelessWorld/Chatterbox-1976.pdf
http://www.diystompboxes.com/smfforum/forums.html?action=printpage;topic=98871.0
andrewF
PostPosted: Wed Aug 20, 2014 3:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Has anyone ever built the chatterbox? That article has been around for years but I have never heard of anybody actually building one.
At one stage Randaleem contacted the designers who gave him permission to do a PCB run, but we all know how that ended up.
Anyway, maybe it is time to do it?
aladan
PostPosted: Wed Aug 20, 2014 4:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, and Andrew YOU are the man to do it!
I'm up for a PCB, obviously.
A.
Audio files: 705
PostPosted: Wed Aug 20, 2014 5:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Might be a good idea to post that in this thread. (or maybe merge them). Cool
