Array of different oscillators?
Page 1 of 1 [4 Posts]
Khepri
PostPosted: Tue Sep 23, 2014 12:11 pm    Post subject: Array of different oscillators? Reply with quote  Mark this post and the followings unread
I know it's possible to create an array of UGens of the same type. How about an array of different types?
SinOsc Sin1;
SawOsc Saw1;
TriOsc Tri1;
[Sin1, Saw1, Tri1] @=> ???[];
Don't fear mistakes. There are none.
- Miles Davis
kingcrabmeat
PostPosted: Wed Oct 01, 2014 10:40 am    Post subject: Reply with quote  Mark this post and the followings unread
I found the answer, thanks to ChucK's console output. I tried UGen out of curiosity and got this:
Code:
cannot assign '@=>' on types 'Osc[]' @=> 'UGen[]'
So, the object you're looking for is, indeed, Osc.
However, anything besides the four standard oscillators is classified under UGen. Therefor, it doesn't seem possible to have both standard oscillators and other UGens in a single array. One may opt to use the Blit UGen objects instead as a workaround.
Khepri
PostPosted: Sun Oct 05, 2014 1:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Code:
Thanks
- Miles Davis
essteb
PostPosted: Wed Nov 05, 2014 1:33 pm    Post subject: in fact it is possible Reply with quote  Mark this post and the followings unread
its possible,
SinOsc sin; Blit blit;
[sin,blit] @=> UGen UGen_array[];
