Using all (computer) keyboard keys
Page 1 of 1 [4 Posts]
WillHS
PostPosted: Mon Oct 27, 2014 7:34 pm    Post subject: Using all (computer) keyboard keys
Subject description: HidMsg.ascii() doesn't differentiate between many keys
I'm interested in making a ChucK program which responds to key events to assist users' typing.
HidMsg.ascii() returns unique ascii codes for most keys, but for many keys like arrow keys, ctrl, alt, shift, home, end and some others, the ascii code returned is the same (0).
I wasn't able to find documentation for the Hid or HidMsg classes.
Is there any way to differentiate between these keys in ChucK?
WillHS
PostPosted: Tue Oct 28, 2014 2:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've found a way to get unique codes from each (computer) keyboard key: HidMsg.which. This seems to return a unique integer for every key on my keyboard.
But will the mapping from key to code be the same of all (or at least english) keyboards?
I would still also like to see documentation for the classes Hid and HidMsg.
PostPosted: Wed Nov 05, 2014 11:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
My guess is that .which() returns common key codes like you can see in other programming languages. In which case they should be consistent between all keybaords. For common keys, they will probably be the same for different languages too, if the differences in layouts aren't too crazy.
PostPosted: Wed Nov 05, 2014 11:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just had a look at my old cli sequencer code, and I use a class called KBHit, and call kb.getchar() on it. I seem to have been able to detect the escape key using this, at least.
