  Twyndyllyngs Live in person Chez Mosc
Instanceof in ChucK?
Page 1 of 1 [3 Posts]
WillHS
PostPosted: Thu Oct 30, 2014 5:15 am    Post subject: Instanceof in ChucK? Reply with quote  Mark this post and the followings unread
In Java, the instanceof keyword can be used to check whether an object is an instance of class x or a sub-class of x.
Is there a way to check if an object is an instance of a particular class or sub-class of a particular class?
kingcrabmeat
PostPosted: Thu Oct 30, 2014 1:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
I doubt that there is such a feature. I would suggest including an identifier variable like so:
Code:
class A {
    0 => int id;
class B extends A {
    1 => id;
A a;
B b;
if( a.id == b.id )
    <<< "same" >>>;
else
    <<< "different" >>>;
You probably considered this already. Anyway, you're right to ask because the documentation on the ChucK website isn't very current. The ChucK mailing list might be a good place to submit questions about bugs and features if not on this forum.
WillHS
PostPosted: Thu Oct 30, 2014 3:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, thanks for the suggestion. Will try the mailing list.
