Joined: Apr 03, 2004 Posts: 24499 Location: The Netherlands, Enschede
Posted: Sat Nov 08, 2014 6:11 pm Post subject:
Synth Noodles Compilation Project Subject description: noodle contributions |
My contribution ... will just post both ... or all three .. or all four
mp3, flac, wren and jpg.
As you can see a noodle is just a compression method oh it is a life form too
The title is "43 - it knobs"
The copyright situation is that you can use this for whatever you like as long as you credit me. When you do not credit me you can still listen. The fine print is :
 '43 - it knobs' by Blue Hell is licensed under a Creative Commons Attribution 4.0 International License. Based on a work at http://electro-music.com/forum/post-405041.html#405041.
There also is a Nord Modular G2 patch involved, it adds a lightly compressed version over the source stream, to give it a bit more body. Also the sundcard adds a bit of echo and reverb.
These recordings are a snapshot of course .. the real thing will be on for a bit longer here
| 43 - it knobs, a noodle, the mp3 version |
 Download (listen) |
| Filename: |
2014-11-08--blue hell--43 it knobs.mp3 |
27.69 MB |
| Downloaded: |
3974 Time(s) |
| 43 - it knobs, a noodle, the flac version |
 Download (listen) |
| Filename: |
2014-11-08--blue hell--43 it knobs.flac |
102.94 MB |
| Downloaded: |
4047 Time(s) |
| 43 - it knobs, a noodle, the wren version |
 Download (listen) |
| Filename: |
new_43.wren |
72.36 KB |
| Downloaded: |
1354 Time(s) |
_________________ Jan
Joined: Dec 11, 2010 Posts: 1025 Location: Toronto, Ontario - Canada
Posted: Sun Nov 09, 2014 6:59 am Post subject:
Here is my contribution. It works well as a song, but not as impressive of a noodle as Jan's track.
If it doesn't make the cut then please let me know why - maybe I can make some changes.
***Edit: This patched maxed out my i3 with 3GB of ram. If you have anything less than that, then it will run sluggish and might lock up wren.***
| Screen shot of Wren patch. |
278.2 KB |
| Viewed: |
1282 Time(s) |
| Wren patch of Ambitious Illusions |
 Download (listen) |
| Filename: |
noodle1g.wren |
95.49 KB |
| Downloaded: |
1345 Time(s) |
| Jacob Watters - Ambitious Illusions |
 Download (listen) |
| Filename: |
Jacob Watters - Ambitious Illusions.wav |
108.22 MB |
| Downloaded: |
3711 Time(s) |
 Download (listen) |
| Filename: |
Jacob Watters - Ambitious Illusions.flac |
42.09 MB |
| Downloaded: |
3684 Time(s) |
 Download (listen) |
| Filename: |
Jacob Watters - Ambitious Illusions.mp3 |
24.55 MB |
| Downloaded: |
3550 Time(s) |
hrastprogrammer
Audio files: 64
Posted: Mon Nov 10, 2014 8:13 am Post subject:
A single C1 note playing a single Tranzistow patch consisting of 4 oscillators, 4 ladder filters and 4 LFOs interacting with each other in a semi-random fashion, slowly evolving in their own directions from a common centerpoint. I started Tranzistow, had a lunch and just stopped recording after returning back ...
Copyright © 2014 by HrastProgrammer. CC BY-NC-ND 4.0
 Download (listen) |
| Filename: |
HrastProgrammer_Four_Generators.mp3 |
22.29 MB |
| Downloaded: |
3562 Time(s) |
 Download (listen) |
| Filename: |
HrastProgrammer_Four_Generators.flac |
105.17 MB |
| Downloaded: |
3711 Time(s) |
_________________ https://www.hrastprogrammer.com/hrastwood/
https://hrastprogrammer.bandcamp.com/ |
Posted: Mon Nov 10, 2014 10:30 am Post subject:
| HrastProgrammer wrote: | | A single C1 note |
Pretty wild note, nice! _________________ Jan
Joined: Apr 24, 2009 Posts: 2506 Location: Bristol UK
Audio files: 500
Posted: Tue Nov 11, 2014 11:23 am Post subject:
This one was made entirely in Madrona Labs Aalto synth plugin. Attached is also a screenshot and the preset itself. I understand that not everybody has bought the plugin but the preset is here for those who are interested.
If needed I can provide a FLAC link but here is just the mp3 for now.
185.81 KB |
| Viewed: |
1240 Time(s) |
| robsol - aalto noodle number two |
 Download (listen) |
| Filename: |
aalto noodle 2.mp3 |
10.34 MB |
| Downloaded: |
3654 Time(s) |
 Download (listen) |
| Filename: |
noodle2.rtf |
2.83 KB |
| Downloaded: |
1312 Time(s) |
_________________ Muied Lumens Sub Forum
Bandcamp |
Jack_Hertz
Audio files: 101
G2 patch files: 7
Posted: Tue Nov 11, 2014 1:06 pm Post subject:
I won't be able to setup the Noodle Comp till next week. _________________ Jack Hertz.com | Aural Films Last edited by Jack_Hertz on Mon Nov 24, 2014 1:18 pm; edited 1 time in total |
ian-s
Audio files: 42
G2 patch files: 626
Posted: Fri Nov 21, 2014 1:33 am Post subject:
Chunk Subject description: a contibution |
flac and prf2
 Download (listen) |
| Filename: |
chunk.prf2 |
15.84 KB |
| Downloaded: |
4769 Time(s) |
 Download (listen) |
| Filename: |
chunk.flac |
57.36 MB |
| Downloaded: |
3736 Time(s) |
Jack_Hertz
Audio files: 101
G2 patch files: 7
Jack_Hertz
Audio files: 101
G2 patch files: 7
Posted: Wed Nov 26, 2014 11:51 am Post subject:
I cooked this Noodle up on the Dual MFOS Soundlab II driving the Nord G2 synthesizers with a Sonuus G2M pitch to MIDI convertor. It is mostly autonomous, but I did some tweaking here and there to tighten things up as it moved along.
377.28 KB |
| Viewed: |
1057 Time(s) |
 Download (listen) |
| Filename: |
Jack Hertz - Red Noodle 2.flac |
168.49 MB |
| Downloaded: |
3556 Time(s) |
 Download (listen) |
| Filename: |
Jack Hertz - Red Noodle 2.mp3 |
34.89 MB |
| Downloaded: |
3434 Time(s) |
_________________ Jack Hertz.com | Aural Films |
Posted: Wed Nov 26, 2014 2:04 pm Post subject:
Djeez .. I can not even use that bandcrap o_o .. it wants flash .. and I have this 'no adobe' rule for my home computers
It also wants cookies to be enabled .. wtf
Good thing we have the mp3's here.
Also .. the buy-me button there ... how is that non commercial?
Edit: some info I collected about Noodles for a lecture that was never held : http://bluehell.electro-music.com/nr/info/forums.html _________________ Jan
Posted: Wed Nov 26, 2014 2:21 pm Post subject:
Nice one Rob! _________________ Jan
Posted: Wed Nov 26, 2014 2:30 pm Post subject:
Re: Chunk Subject description: a contibution |
| ian-s wrote: | | flac and prf2 |
Great one Ian! _________________ Jan
Posted: Wed Nov 26, 2014 2:46 pm Post subject:
| Jack_Hertz wrote: | | It is mostly autonomous, but I did some tweaking here and there to tighten things up as it moved along. |
cheating!
It sounds good though. _________________ Jan
Audio files: 500
Posted: Wed Nov 26, 2014 5:01 pm Post subject:
Great work Jack! Thanks for taking the time to organise this!
| Blue Hell wrote: | Djeez .. I can not even use that bandcrap o_o .. it wants flash .. and I have this 'no adobe' rule for my home computers
Works fine here, on a noFlash computer. _________________ Muied Lumens Sub Forum
Bandcamp |
Jack_Hertz
Audio files: 101
G2 patch files: 7
Posted: Wed Nov 26, 2014 6:46 pm Post subject:
Edit: some info I collected about Noodles for a lecture that was never held : http://bluehell.electro-music.com/nr/info/forums.html |
Should have warned you, its, uh, like the rest of the internet that rely on such things as part of their <cough> design.
As for the non-commercial. All tracks are published under the CC license: Attribution Non-commercial Share Alike. The "BuyNow" is, unfortunately, a function of Bandcamp. Most people enter $0 for the free download, but Bandcamp relies on some small number of people paying out or courtesy so they can take a fee from that. _________________ Jack Hertz.com | Aural Films Last edited by Jack_Hertz on Wed Nov 26, 2014 8:24 pm; edited 1 time in total |
Jack_Hertz
Audio files: 101
G2 patch files: 7
Posted: Wed Nov 26, 2014 7:02 pm Post subject:
| Blue Hell wrote: | | Jack_Hertz wrote: | | It is mostly autonomous, but I did some tweaking here and there to tighten things up as it moved along. |
cheating!
It sounds good though. |
Long story... but, there was a big discussion on Facebook about what is, and is NOT, a Noodle. Ultimately, I felt all that matters is people try to do something with the concept without a lot of rules getting in the way. If someone wants to try with Apps, MIDI gear, or whatever, why not? That said, I just liked this one most and had to be honest about tweaking it a bit.  _________________ Jack Hertz.com | Aural Films |
Audio files: 500
Posted: Thu Nov 27, 2014 2:51 pm Post subject:
| Jack_Hertz wrote: | | Blue Hell wrote: | | Jack_Hertz wrote: | | It is mostly autonomous, but I did some tweaking here and there to tighten things up as it moved along. |
cheating!
Long story... but, there was a big discussion on Facebook about what is, and is NOT, a Noodle. Ultimately, I felt all that matters is people try to do something with the concept without a lot of rules getting in the way. If someone wants to try with Apps, MIDI gear, or whatever, why not? That said, I just liked this one most and had to be honest about tweaking it a bit.  |
For me it's easy. If someone starts fiddling with it, that person is part of the noodle. You can formalise it by stating rules for your behaviour, for example: "If the LFO speeds up, I trigger sample X" etc etc...
...of course, you could continue along that philosophy and look at every aspect of a person's behaviour as a set of rules. Many people do that as a career.  _________________ Muied Lumens Sub Forum
Bandcamp |
Jack_Hertz
Audio files: 101
G2 patch files: 7
Posted: Fri Nov 28, 2014 9:29 am Post subject:
| robsol wrote: | | For me it's easy. If someone starts fiddling with it, that person is part of the noodle. |
I wish I had thought of that. Perfect. _________________ Jack Hertz.com | Aural Films |
Posted: Tue Dec 02, 2014 1:17 pm Post subject:
Late in with a quiet one. All done in Nord Modular G2, running the attached patch. No processing, besides normalizing the recording in Audacity.
 Download (listen) |
| Filename: |
Santas Cavern in February.prf2 |
15.82 KB |
| Downloaded: |
4641 Time(s) |
 Download (listen) |
| Filename: |
Santas Cavern in February.flac |
58.04 MB |
| Downloaded: |
3587 Time(s) |
_________________ Antimon's Window
Jack_Hertz
Audio files: 101
G2 patch files: 7
Posted: Wed Dec 03, 2014 9:39 am Post subject:
Thanks, Stefan. This is great. Your track has been added to the compilation as well:https://auralfilms.bandcamp.com/album/noodles
FYI. There is NO DEADLINE on this project. Everyone is welcome to participate when they are ready. All you need to do is post in this topic.
EMjoy! _________________ Jack Hertz.com | Aural Films |
Posted: Thu Dec 04, 2014 1:43 pm Post subject:
| Antimon wrote: | | Late in with a quiet one. |
Nice one! _________________ Jan
Posted: Thu Dec 04, 2014 2:02 pm Post subject:
Hey thanks Jack and Jan! Now to find some time to listen to all the other great noodles... _________________ Antimon's Window
Synthesizerman
Posted: Sat Dec 06, 2014 2:03 pm Post subject:
Automatic Duet for Two VCOs |
Here you are, Jack!
 Download (listen) |
| Filename: |
Automatic_Duet_for_Two_VCOs.flac |
42.2 MB |
| Downloaded: |
3587 Time(s) |
| Doug Lynner aka Synthesizerman - Automatic Duet for 2 VCOs |
 Download (listen) |
| Filename: |
Automatic_Duet_for_2_VCOs.mp3 |
19.28 MB |
| Downloaded: |
3828 Time(s) |
Jack_Hertz
Audio files: 101
G2 patch files: 7
Posted: Sun Dec 07, 2014 10:31 am Post subject:
Re: Automatic Duet for Two VCOs |
| Synthesizerman wrote: | | Here you are |
Nice :-) _________________ Jan
